EAGLE User Support (English) Version 6.0 no longer compatible with FreeRouting.net
  • Replies 14 replies
  • Subscribers 189 subscribers
  • Views 1140 views
Mawrob
Mawrob over 14 years ago
Just wanted to let folk know who use FreeRouting that the brd_to_dsn ulp no longer works and throws the following error:
file path(119)
syntax error
and stops at:
real mm2u(real val)
The new "copy from" feature also blew up and threw a bunch of errors.  I have an email into support and hopefully it is a mistake on my part and not a major bug.
Version 6.0 appears to have some great new features but the schematics, boards, and libraries do not appear compatible with 5.11.  I made the mistake of upgrading without backing up my main library and have lost about a months worth of footprints.
Be aware!
file path(119)
syntax error
and stops at:
real mm2u(real val)
Be aware!
    On 14/12/2011 01:56, Mawrob wrote:
    I have uploaded to Cadsoft the brd_to_dsn_V6.ulp file, to generate the
    input for Freerouting. This is a replacement of the file I uploaded
    yesterday.
    The changes are required as the internal unit in EAGLE changed from
    1/10000 mm to 1/320000 mm between V5 and V6.
    It seems to work OK now (in the file of yesterday the via's were too
    small). I have not tested with a GRID setting in MIL units though.
    Robert
  • Mawrob
    Mawrob over 14 years ago in reply to e14 Contributor
    Thanks for the helpful suggestion.  I managed to find a number of parts in existing V5 schematics and I was able to use: exp-project-lbr.ulp (I think) to export my parts to a local library.
    The strength of Eagle is definitely the community of users.
    e14 Contributor over 14 years ago in reply to Mawrob
    Mawrob <communitymanager@premierfarnell.com> wrote:
    Sorry about the confusion: the latter -
    "once you've saved the files
    you brought into 6 they can no longer open in 5.11?"
    I made the foolish mistake of updating my library in 6.0.? Now that we have had to revert back to
    5.11 my library is naturally unusable and we have lost a month of changes because we were careless a
    nd did not back up all our Eagle data before upgrading.
    Try to export as script in 6.0 and import the script in 5.11. If it chokes,
    write a filter. Otherwise a backup can also help image
    Uwe Bonnes                bon@elektron.ikp.physik.tu-darmstadt.de
    Institut fuer Kernphysik  Schlossgartenstrasse 9  64289 Darmstadt
    Tel. 06151 162516 -
    Fax. 06151 164321 -
    I made the foolish mistake of updating my library in 6.0.  Now that we have had to revert back to 5.11 my library is naturally unusable and we have lost a month of changes because we were careless and did not back up all our Eagle data before upgrading.
    Try to export as script bin 6.0 and import in 5.11. If it chokes, write a filter.
    Tel. 06151 162516 -
    Fax. 06151 164321 -
    Warren Brayshaw wrote:
    I suspect you may be able to rebuild the v5 library from the v6
    library by using the ULP at
    ftp://ftp.cadsoft.de/eagle/userfiles/ulp/lbr-contents-dump.zip
    Open the v6 version of the library.
    Run the ULP. It will place files in a new folder in the v6 library
    directory
    Then in v5 build a new library using those script files
    I have not tested this other than looking at the files produced by v5
    running the ULP. Hopefully v6 will run the ULP (Some ULPs will need
    modifying to run in v6)
    Note I did have to modify the ULP include file to get past file paths
    with spaces so use the attached file (modified).
    Worth a try.
    Warren
    Web access to CadSoft support forums at www.eaglecentral.ca.  Where
    the CadSoft EAGLE community meets.
    I should have pointed out that  this solution is for the Windows environment
    as the ULP uses system() to start the CMD processor of windows. Here it
    makes the new folder to place the files into.
    That would need to be modified mac and linux
    Warren
    news.cadsoft.de
    I suspect you may be able to rebuild the v5 library from the v6 library by
    using the ULP at
    directory
    Note I did have to modify the ULP include file to get past file paths with
    Worth a try.
    Warren
    On 14/12/2011 16:01, John Friede wrote:
    >>> Hi,
    Robert,
    Please clarify what you mean. Are libraries, schematics & boards created
    in 5.11 not usable in 6, or is it just that once you've saved the files
    I saw the following:
    I could load the design with this modification of the ULP in Freerouting
    OK, and it did a proper routing job.
    When I generated in Freerounting the script file to load the routed
    wiring back into the EAGLE board, I found that the SRC file (The
    xxx_gen_drufile.scr) generated VIA commands that are not correct.
    In particular, it specified in the VIA command the via size in a
    floating point E-format that is not supported. I asked in another topic
    in this forum if that was a change from V5 to V6, but in effect, that
    has nothing to do with EAGLE. I later tested that the .scr files I got
    back in V5 have the correct format.
    I did not have the time yet to see where the problem is, like reporting
    the grid size incorrectly to force this format. As I am in the middle of
    a project where I depend on it, I will make some time available soon...
    Robert
    NB EAGLE 6 has a different file format and you cannot go back to V5. One
    part of my project is impacted by that, and I might recover my work for
    switching to V5 thanks to the backup files that Eagle automatically
    generates.
    But I understand (being in the software application business myself)
    that these changes are needed to improve a product, and that it is
    unhealthy and unrealistic to carry legacy designs onwards.
  • Mawrob
    >>> Hi,
    >>> file path(119)
    >>> syntax error
    >>> and stops at:
    >>> real mm2u(real val)
    >>> Be aware!
    >>> Thanks
    >>> Hi,
    >>> file path(119)
    >>> syntax error
    >>> and stops at:
    >>> real mm2u(real val)
    >>> Be aware!
    >>> Thanks
    >> Correct. It is due to the fact that 3 subroutines (mm2u is one of them)
    >> are now a default name in EAGLE v6, causing a conflict. I resolved that
    >> by changing the first letter of these routines to uppercase (Mm2u, etc)
    >> in the ULP. I did not bother to look if the default routines can replace
    >> the existing code in the brd_to_dsn ulp.
    >> This ULP then runs correctly.
    >> One problem remains:
    >> The SCR output file now has floating point numbers for the via size,
    >> which confuses EAGLE. Have not found a solution yet. I might need to set
    >> the grid to a different value.
    >> Robert
    >> NB since the brd_to_dsn ulp is 64 KB, I don't think I can attach it.
    Robert,
    All files from versions prior to V6 can be used in V6, but as soon
    as you save such a file in V6 you can't load it in one of the
    previous versions.
    Richard Hammerl
    >> Hi,
    >> file path(119)
    >> syntax error
    >> and stops at:
    >> real mm2u(real val)
    >> Be aware!
    >> Thanks
    >> Hi,
    >> file path(119)
    >> syntax error
    >> and stops at:
    >> real mm2u(real val)
    >> Be aware!
    >> Thanks
    Robert
    Robert,
    created in 5.11 not usable in 6, or is it just that once you've saved
    the files you brought into 6 they can no longer open in 5.11?
