EAGLE User Support (English) Trouble with Eagle 6 on Ubuntu 10.04
  • Replies 11 replies
  • Subscribers 190 subscribers
  • Views 2166 views
I downloaded the .run file from the website today for Eagle 6, but when I tried to run it, I received this error:
/tmp/eagle-setup.6445/eagle-6.0.0/bin/eagle: error while loading shared libraries: libpng14.so.14: cannot open shared object file: No such file or directory
I tried to follow the advice given for 11.04 (seen here: http://www.element14.com/community/message/41329#41329/l/re-solved-problem-trying-to-install-eagle-6-over-linux-ubuntu-1110), but for me, the command "tar xf" does not work on .txz files. When I manually extracted the contents of the file and ran the doinstall.sh, but it gives me more errors (namely, could not cd to usr/lib).
Any specific advice for 10.04?
  • bronson
    bronson over 14 years ago
    I'm running 11.04 but I got the same error (missing libpng14.so.14).
    I followed these instructions and they worked great: http://balubati.atw.hu/blog/index.php?entry=entry111108-115133
    Basically, I did this:
    $ wget ftp://ftp.cadsoft.de/eagle/program/6.0/eagle-lin-6.0.0.run
    $ sed -e '1,/^__DATA__$/d' eagle-lin-6.0.0.run > eagle-lin-6.0.0.tar.bz2
    $ tar xvjf eagle-lin-6.0.0.tar.bz2
    $ cd eagle-6.0.0/bin
    $ wget http://dl.dropbox.com/u/4295670/eagle_libs.tar.bz2
    $ tar xvjf eagle_libs.tar.bz2
    $ mv eagle eagle.orig
    $ echo 'LD_LIBRARY_PATH="$(dirname "$0")" "$(dirname "$0")/eagle.orig" $@' > eagle
    $ chmod a+x eagle
    And now Eagle appears to run like normal.
    Hope this helps.
        - Scott
    P.S. I can't vouch for the authenticity/security of the eagle_libs files.  They poster seemed like a nice guy but use them at your own risk!
