EAGLE User Support (English) dos commands
  • Replies 9 replies
  • Views 1150 views
dos commands
Hello.
I would like to know all the commands (parameters) that can be writen in dos command line (not the Eagle command line).
Thanks.
    On 17.12.2011 16:29, David Malnar wrote:
    There is a command line version of Eagle for use in scripts and the like.
    This is what I'm looking for,but cannot find.
    I have used the "dos" word only to distinguish the Eagle command line from the dos stile command line.
    So please somebody confirm if Eagle has a windows command line shell dos stile cmd.exe interface and woh to use it.
    It is possible to start EAGLE with the option -S which specifies
    a script file that can contain EAGLE commands like SHOW.....
    Richard Hammerl
    So please somebody confirm if Eagle has a windows command line shell dos stile cmd.exe interface and how to use it.
    Element 14 User wrote on Sat, 17 December 2011 08:21
    Ha,ha,do you really think that I'm using the real dos? It is obvious
    that I'm talking about the command line shell in windows (CMD.EXE).
    Not obvious at all since you specifically said something different.  Learn
    to say what you actually mean.
    Quote:
    I just want to open Eagle from other program (through the command line
    shell in windows)
    I've never used it, so I don't remember the details, but I definitely
    remember seeing it documented.
    Quote:
    About this forum,it has the Eagle tittle,so why is this not the right
    forum?
    You originally asked about DOS commands, which have nothing to do with
    Eagle.  Even if you really meant Windows command line commands, that still
    has nothing to do with Eagle.  It now seems you are asking about yet
    something else.
    Decide what you really want and then ask about that clearly.
    Ha,ha,do you really think that I'm using the real dos?It is obvious that I'm talking about the command line shell in windows (CMD.EXE).
    I just want to open Eagle from other program (through the command line shell in windows)  , open a board file and SHOW (highlight) a specific component.
    Till now I managed to open the brd file,but don't know how (if) to pass the SHOW parameter.
    About this forum,it has the Eagle tittle,so why is this not the right forum?
    Op Sat, 17 Dec 2011 13:23:57 +0100 schreef David Malnar
    <communitymanager@premierfarnell.com>:
    Hello.
    Thanks.
    Although it's rather unclear what you mean, I assume you want the command
    line parameters that Eagle can use.
    The easiest way is to open the help menu and type 'command line
    parameters'. You'll get an nice list ..
    (it's a rather long list, so I won't copy it here)
    If you don't have Eagle already, download the freeware version: All
    official documentation is contained within the download.
    Richard
    rk wrote on Sat, 17 December 2011 07:44
    All parameters are listed in the online help under the topic "Command
    Line Options".
    No, those are the Eagle commands.  The OP was specifically asking about DOS
    commands.
    Element 14 User wrote on Sat, 17 December 2011 07:23
    Then go read a DOS manual.  What bizzare mis-logic made you ask here?
    Besides, DOS hasn't been used in years and Eagle doesn't run on it.  The
    regular command line shell in windows (CMD.EXE) still probably supports
    many old DOS commands, but if you want real DOS you'll have to run real
    DOS.  Again, this has nothing whatsoever to do with this forum.
    So,all the commands that can be input in Eagle Command Line ,can also be written from command prompt (dos).Is this true?
    Can you give a sample ,how to pass the parameter (command) in dos?
    Am 17.12.2011 13:23, schrieb David Malnar:
    Line Options".
    Rene
