EAGLE User Support (English) PCB MANUFACTURERS
  • Replies 12 replies
  • Subscribers 191 subscribers
  • Views 1505 views
PCB MANUFACTURERS
Hi My name is TJ , I am new here and still kinda feel my way around.
For starters, can anybody refer me to a resonable inexpensive pcb manufacturer for short runs of 10x  or so pcb's for research and developing?
Also what is a good rate per square inch nowadays for a normal 2 sided PCB with silkskreen?
Tnx in advance
tj-
  • fustini
    fustini over 14 years ago
    Howdy,
    I just did a recent order of a small 2 layer PCB (a Christmas tree) from Seeed Studios' Fusion PCB Service and SparkFun's BatchPCB.  Seeed was $30 for qty 10 while BatchPCB was $28 for qty 2.  I ordered from both on Nov-30 and both arrived today Dec-16 (in Chicago, IL, USA).
    BatchPCB
    http://batchpcb.com/index.php/Products
    SeeedStudio
    http://www.seeedstudio.com/depot/fusion-pcb-service-p-835.html?cPath=185
    However, I should state that I haven't verified how well either order works as I'm just ordering the BOM right now.image
    Cheers,
    Drew
    "tj snyman" <communitymanager@premierfarnell.com> wrote in message
    news:338545419.12061324055696381.JavaMail.jive@flcspu-csapp-01.premierfarnell.com...
    developing?
    with silkskreen?
    Tnx in advance
    tj-
    If you are displaying the command texts menu (typically on the right side of
    your screen), there should be links for "Design Link" and "PCB Quote" Try
    these to see about ordering.  If it doesn't work, you can open the ulp
    directly as designlink-somethingorother.ulp
      I tried this a few times and for prototypes, got a better price from
    APCircuits.com in Alberta, Canada.
    If you use APC, I suggest downloading the APClient.zip
    http://www.apcircuits.com/resources/downloads/downloads.html
    I'm in NY, USA and found them very easy to deal with. The APClient also
    makes it very easy to re-order boards. Their system is highly automated and
    you pay extra for 'hand-holding'. Likewise there is a discount for using a
    credit card.
