EAGLE User Support (English) PCB MANUFACTURERS
  • Replies 12 replies
  • Subscribers 191 subscribers
  • Views 1498 views
PCB MANUFACTURERS
Hi My name is TJ , I am new here and still kinda feel my way around.
For starters, can anybody refer me to a resonable inexpensive pcb manufacturer for short runs of 10x  or so pcb's for research and developing?
Also what is a good rate per square inch nowadays for a normal 2 sided PCB with silkskreen?
Tnx in advance
tj-
  • rachaelp
    rachaelp over 10 years ago in reply to e14 Contributor
    And you're only a little over 4 years late to this thread..... I'm fairly sure TJ had his boards long ago.....
    [deleted]
    I have found iTeadStudio's PCB service the most inexpensive one for prototyping. Here's the link:
    http://iteadstudio.com/store/index.php?main_page=index&cPath=19_20
    I tried their service few weeks ago to make some breadboard modules for PIC microcontrollers and the PCBs were really good. Here's a picture showing the PCB.
    Hi TJ,
    Beta LAYOUT is a PCB manufacturer specialized in prototypes. They are in Europe and have a US facility.
    They offer a ULP plus a button for EAGLE to calculate PCBs and component assembly with two mouse clicks:
    http://www.pcb-pool.com/ppus/service_downloads.html
    The auto install worked like a charm on my Win XP OS.
    Andrew Feldhaus wrote on Mon, 19 December 2011 04:14
    I'll throw my 2c in here for those in Europe, in particular.  I've used
    Olimex (www.olimex.com/pcb) quite a bit for small volumes.
    A few years back I attempted to try out Olimex.  However I found out that
    their design rules were very unusual.  The same set of gerber and drill
    files that all other board houses could fab from violated their rules.  If
    forget the details, but I remember unusual hole sizes was one issue, and
    they insisted on everything being in metric instead of simply converting as
    needed.  The messages I got from them were very terse and therefore
    ambiguous, so it took some back and forth to figure out what exactly the
    problem was.  The tone was also deliberately insulting.  No thanks.  I went
    elsewhere and haven't been back.  This was a few years ago, so things may
    have changed.  However, look thru their web site very carefully,
    particularly at their design rules and other restrictions.
    For well done professional prototypes with solder mask and silkscreen,
    check out Gold Phoenix (http://www.goldphoenixpcb.com).
    Tnx in advance
    tj-
    Olimex (www.olimex.com/pcb) quite a bit for small volumes.  In recent
    years the quality has been very good.  A 160x100mm double sided panel
    will cost 30 EUR plus shipping and VAT.  There are more details on their
    site.
    They also accept EAGLE .brd files directly, which is nice if you're not
    comfortable generating Gerber batches.
    Andrew
    0xADF
    e14 Contributor over 14 years ago in reply to fustiniadmin
    Drew Fustini wrote:
    Hi Warren,
    Unfortunately, the issue is not resolved yet.  Our framework vendor
    recently informed us that they will not be fixing the issue, so we
    will have to address it directly.  I can't give an estimate for when
    it will be resolved at this point.  I know this issue negatively
    impacts communication on these newsgroups and will attempt to
    prioritize it with our team.
    One improvement that will be released next week is that the From:
    address for posts exported from element14 will be unique per-user.
    This will resolve the issue where element14 posters are misidentified
    on EAGLE Central.
    Drew
    On 12/16/2011 08:15 PM, Warren Brayshaw wrote:
    >> Drew Fustini wrote:
    >>> However, I should state that I haven't verified how well either
    >>> order works as I'm just ordering the BOM right now. Image:11 - 1.jpg
    >> Drew, I thought you were going to fix this attachment issue at
    >> Element14
    >> Warren
    Thanks for the update Drew
    Warren
    news.cadsoft.de
  • fustiniadmin
    fustiniadmin over 14 years ago in reply to e14 Contributor
    Hi Warren,
    recently informed us that they will not be fixing the issue, so we will
    have to address it directly.  I can't give an estimate for when it will
    be resolved at this point.  I know this issue negatively impacts
    communication on these newsgroups and will attempt to prioritize it with
    our team.
    address for posts exported from element14 will be unique per-user.  This
    will resolve the issue where element14 posters are misidentified on
    EAGLE Central.
    Drew
    Drew Fustini wrote:
    >> However, I should state that I haven't verified how well either order
    Drew, I thought you were going to fix this attachment issue at Element14
    Warren
    Warren
    news.cadsoft.de
  • fustini
    fustini over 14 years ago in reply to fustini
    Another low-cost batch service I've used was DorkbotPDX PCB.  The boards were high quality and turn around was about 3 weeks from what I recall:
    http://dorkbotpdx.org/wiki/pcb_order
    Cheers,
    Drew
