EAGLE User Support (English) Problems with "Change Package" in CPOL-EU component
  • Subscribers 189 subscribers
  • Views 1547 views
When I change package for example from CPOL-EUE2-5 (CPOL-EU) to
CPOL-EUE2.5-7 (CPOL-EU) I lost schematic/board consistency. I think that
this an error in RCL library - how can I fix this ?
    e14 Contributor over 14 years ago in reply to ClaveFremen
    Dnia 19.12.2011 o 01:29 Dario Inserra
    <communitymanager@premierfarnell.com> napisał(a):
    I'm having the same problem...
    As Warren Brayshaw wrote problem exist when pin (or pad) has "+" or "-"
    name. I simply use Ultraedit and globally change "" to "V" and "-" to
    "V-" in all *.lbr files. Now everything works fine.
    Leszek Ulman
    Leszek Ulman wrote:
    More informations follow:
    Eagle 5.11 works fine.
    Problem is with Eagle 6.0.0 Demo and 6.0.1 Beta Demo.
      1. Create simple schematic - 01.jpg,
          Resistors are R-EU_0207/10 (R-EU_),
          Capacitors are CPOL-EUB45181A (CPOL-EU),
      2. Make a board - 02.jpg,
      3. Rearrange parts - 03.jpg,
      4. Route the board - 04.jpg,
      5. Change resistors package - 05.jpg - looks good,
          Resistors are now R-EU_0207/15 (R-EU_),
      6. Move resistors - 06.jpg - ALL OK!,
      7. Change capacitors package - 07.jpg - don't look good,
          Capacitors are now CPOL-EUB45181C (CPOL-EU),
      8. Move capacitors - 08.jpg - AIRWIRES ARE MISSING !,
      9. 1st warning - 09.jpg,
    10. 2nd warning - 10.jpg,
    11 ERC Errors - 11.jpg.
    Because problems are with capacitors and NOR resistors I think that
    'RCL' library is damaged.
    Leszek Ulman
    Looking at the library in v5 I'd guess that v6 is having an issue with the
    pins being named  "+"  and  "-" .  I feel I saw a beta comment earlier with
    symbols like + and - causing an issue.
    Warren
    news.cadsoft.de
    autodeskguest over 14 years ago in reply to e14 Contributor
    Leszek Ulman
    Warren
    news.cadsoft.de
  • ClaveFremen
    ClaveFremen over 14 years ago
    Because problems are with capacitors and NOR resistors I think that 'RCL'
    library is damaged.
    Leszek Ulman
    I don't think so. Typically, consistency problems arise when you
    (accidentally?) have closed one of the editor windows and then changed
    only the other.
    Change the package back in the schematic, then run ERC - it will report
    if consistency is OK again (if not, do all necessary changes until it
    is). After that, change the package to the desired one (while the board
    is still open).
    Tilmann
