EAGLE User Support (English) Eagle 6.0 - bug and segfault in package editor when ripping up wire
  • Views 360 views
atelszewski
atelszewski over 14 years ago
First off all, I'm not sure if it is proper place to tell about, but I don't know any other (please redirect me if bugs should be reported somewhere else).
Steps to reproduce:
1. Create package.
2. Place wire in Top or Bottom layer.
3. Try to ripup the wire.
After this steps Eagle crashes with segfault (three examples):
eagle[24242]: segfault at 5c ip 0811a9af sp bfaa8710 error 6 in eagle[8048000+dba000]
eagle[24273]: segfault at 5c ip 0811a9af sp bfc9d6c0 error 6 in eagle[8048000+dba000]
eagle[24406]: segfault at 5c ip 0811a9af sp bff150e0 error 6 in eagle[8048000+dba000]
The operating system is Slackware 13.37 Linux.
Best regards,
Andrzej Telszewski
    On 19.12.2011 10:05, Andrew Feldhaus wrote:
    On 18/12/2011 17:58, Andrzej Telszewski wrote:
    >> Steps to reproduce:
    >> 1. Create package.
    I am also seeing this on Eagle 6.0.1 Win7/x64. Placing a wire is not
    necessary to cause the crash -- merely entering "RIPUP" into the command
    bar when in package editing mode causes the program to crash after
    presenting the "The Ripup command can only be used in a board!" popup is
    cleared.
    Andrew
    0xADF
    We will check this.......
    Richard Hammerl
    Steps to reproduce:
    1. Create package.
    cleared.
    Andrew
    0xADF
