I've inherited an Eagle schematic that has three or four separate clusters
of components . Each cluster has a separate function in the design (one
cluster includes all the power supplies, another does the drivers and
buffers an another describes the microprocessor connections), each cluster
has connections to the others.
I'd like to remove one of the clusters, I think it only has two connections
to the rest of the schematic, if I'm right then I know it's safe to remove
that cluster, if I'm wrong then it could all go horribly wrong.
How can I tell what the cluster is connected to? currently I've been
right-clicking on each net, and then clicking on 'show' to see what get's
highlighted in the rest of the schematic. This is a rather slow process and
I could easily miss something (the schematic is quite complex) is there a
better way of doing this?
Web access to CadSoft support forums at www.eaglecentral.ca. Where the CadSoft EAGLE community meets.
