EAGLE User Support (English) EAGLE upgrade impossible  .....
  • Replies 7 replies
  • Views 729 views
Dear all, especially CadSoft team ...
From your site :
Upgrade system under maintenance
Upgrade system is currently under maintenance and will be available shortly.
since few days.
And my question : how to test Eagle 6.0 without upgrading ?????
br
Grzegorz Zalot
complex ltd.
office tel/fax : +48 32 2505840
mobil : +48 501 301515
    Marvin Dawson wrote on Tue, 20 December 2011 20:39
    Another WARNING / CAUTION that they do not warn you about:
    DO NOT OPEN ANY PROJECTS OR LIBRARIES WITH V6.0 without first saving
    BACKUPS of ALL FILES, since V6.0 will "UPGRADE" all files to new XML
    format AND YOU CANNOT REVERT them back to V5.11 or earlier versions.
    I couldn't reproduce this.  I just opened an EAGLE 5 design (both by
    opening the project and the schematic/pcb directly).  Closing without
    saving had no effect on the files that were there.
    Now if you went ahead and saved the files then yes, they will write the
    files in V6's XML format and there's no easy way to get back.  I don't
    think it should be a surprise that EAGLE would do this.
    I have argued for awhile that EAGLE should have a "Save As" option to save
    into old formats.  I understand there are complications with this, but as a
    design house we have to deal with files in all sorts of formats.  This
    would give everyone the benefit of the new features of the program and
    still be able to support clients on older versions.
    However, I do agree that CadSoft should have handled this better.  A
    warning when changing the format of the file would be sufficient.  There is
    a warning when the .epf file is rewritten from version to version so at
    least that should be done.
    I would argue that the best option would be to change the file extension
    itself.  EAGLE V6 should no longer use .sch and .pcb, just like Microsoft
    Word doesn't use .doc anymore.  The extension should be changed to .schx
    and .pcbx or something similar.  That way, this is a moot issue since the
    new files will be different and the user will still have the old version of
    the files around if they want them.
    As an aside, I have all my files stored in revision control so I can play
    with them freely and not worry about corrupting the local copy and I highly
    recommend this for anyone doing serious design work.  You will get whatever
    time it takes you to setup back ten-fold when issues occur--and they will
    occur.
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    Hello Warren Brayshaw !:
    You need to have v6 use its own location for eaglerc.usr. If you don't it
    may use the v5 eaglerc and with common project names between the versions
    you can accidently load and save your v5 design as v6. Ouch!
    Yes ! I am wondering why CadSoft is NOT able to change the name of the
    config file and this workaround is really necessary !!!
    Change the desktop icon that launches v6 so that it starts eagle with the -U
    switch so it will look something like eagle.exe -Ufilepathforeaglerc.usr
    It may take a bit of patience to get the file name string correct if it
    contains spaces. Mine looks like so:
    "C:\Documents and Settings\Warren\NewEagle2\bin\eagle.exe" -U'C:\Documents
    and Settings\Warren\NewEagle2\eaglerc.usr'
    Eagle will now place the  eaglerc.usr  file into the folder 'NewEagle2'
    instead of where the $HOME environmental variable says to.
    Good advice but .... CadSoft please think about this problem seriously !!!
    Another possibility is to change the name of the eaglers file by editing
    the exe with a HEX editor. But the question WHY is still here ...
    best regards
    Grzegorz Zalot
    complex ltd.
    http://www.complex.org.pl/
    It is said in places but it is not "in your face" and it should be.
    It's to early to use v6 for production. Just to many fixes needed at present
    but  the more people that try it out and report issues the sooner it will
    become solid.
    Work on a copy of your libraries, ulp, scripts and design files so you dont
    have to restore the backups if you wish to revert to v5.
    V6 will install in its own folder which is the first step in isolating the
    versions.
    There are  more things you should do and change immediately after installing
    v6.
    Do these things before ever opening a file.
    I'll talk windows here.
    Set the directories in Control Panel. They need to point to different
    folders than v5.
    Remember they should point to the COPIES of your personal libraries, ulp,
    script etc.
    The  $eagledir paths should be OK as in theory they point to the path of
    this installed instance of Eagle (v6)
    There could be a $Home path in the project path when you load v6 (I saw it
    but I may have caused it ) so removing that path would be a good idea.
    That should do it. Others can comment if I missed something.
    Warren
    news.cadsoft.de
    On 12/20/2011 11:43 AM, Grzegorz Zalot wrote:
    Hello Jorge Garcia,
    >> Use EAGLE 6.0 in freeware mode, and make a simple board that's if you
    >> want to test it.
    I cant use Eagle in freeware mode - my projects are too complex .....
    >> If you want to upgrade it, for the moment you have to call it in
    >> since as you've noticed the upgrade site is down due to technical
    >> difficulties.
    Interesting .... this is for many days !!! I cant imagine the upgrade
    prices are not known ! Of course I can call the German CadSoft, I speak
    German, but ...
    Thanks and best regards
    Grzegorz Zalot wrote on Tue, 20 December 2011 14:43
    Hello Jorge Garcia,
    you
    want to test it.
    difficulties.
    German, but ...
    Hi Grzegorz,
    This won't help you personally, but for those in North America I have the
    upgrade prices online and you can order the EAGLE V6 upgrade online at
    www.eaglecentral.ca
    For Upgrading Standard License go here
    http://www.eaglecentral.ca/eagle/eagle-v6-license-upgrade/eagle-v6-standard-upgrade.
    For Upgrading Professional License go here
    http://www.eaglecentral.ca/eagle/eagle-v6-license-upgrade/eagle-v6-professional-upgrade.
    Cheers,
    James.
    Hello Jorge Garcia,
    want to test it.
    difficulties.
    German, but ...
    Grzegorz Zalot
    complex ltd.
    From your site :
    >> shortly.
    since few days.
    br
    Hi Grzegorz,
    want to test it.
    If you want to upgrade it, for the moment you have to call it in since
    as you've noticed the upgrade site is down due to technical difficulties.
    hth,
    Jorge Garcia
