EAGLE User Support (English) Version 6.0 crash
  • Subscribers 189 subscribers
  • Views 438 views
Version 6.0 crash
Four times now, I have had the new Eagle version crash when I try to save a schematic under a new name after a (long) routing or partial routing has been done. Not sure if that is the exact reason for the crash, but crash happens right when I try to save with new name.
TC
  • CSWalt
    CSWalt over 14 years ago in reply to e14 Contributor
    On 01/16/12 09:57, Andrew Feldhaus wrote:
    On 14/01/2012 18:16, imagineering wrote:
    >> When I try to hand route a wire that should end at a pad or wire on
    >> the same layer, the router does not snap to the end point or complete
    >> the routing until I select it again and route the tiny little airwire
    >> that results from it not having snapped to the end point where
    >> routing should have completed at the previous step.
    This issue is known and will be fixed in Beta 6.1.1, according to Walter
    Spermann in the eagle.betatest thread "Possible routing bug".
    It's discussed in more detail in the "in V6.0.0 manual routing got
    really hard" thread in the eagle.support.eng forum.
    I don't know about the status of the other problems you reported, however.
    All the best,
    Andrew
    0xADF
    You are right, this was a misunderstanding between me and my colleague.
    Btw, please report bugs to eagle.support.eng forum or to eagle.betatest
    if its a beta version.
    Walter Spermann
    Walter Spermann
    Softwareentwicklung
    CadSoft Computer GmbH
    Pleidolfweg 15
    84568 Pleiskirchen
    Tel.: 08635/6989-10
    www.cadsoft.de
    All the best,
    Andrew
    0xADF
    There is yet another problem with the router that is still in Eagle v6.1.0 I had mentioned this to George at cadsoftusa and he said it was being adressed but the problem is still there.
    When I try to hand route a wire that should end at a pad or wire on the same layer, the router does not snap to the end point or complete the routing until I select it again and route the tiny little airwire that results from it not having snapped to the end point where routing should have completed at the previous step. The workaround of reselcting and routing it the second time obviously works, but it is still a bug that needs to be addressed. V5.11 (and others before) never had this problem.
    Also discovered another problem with the program. Not sure if this problem is in versions of Eagle before v6.0 or not, but it is in v6.0
    After running the autorouter for a while, I clicked "Stop" to pause the routing process. Then I did a "Save As" with a new filename. When I returned to try to continue the routing process, there was no option to continue. I checked the directory and Eagle did not save the .job file (routing status and memory buffer) along with the new filename. I made a copy of the most recent .job file under the old filename, and then renamed the copy to the new filename that I used for "Save As". This solved the problem and when I opened the new file again, it allowed me to resume the routing from where it left off, but I would suggest the .job file should be saved under the new filename when using "save as".
