EAGLE User Support (English) v6 ignored Options Directories entries
  • Replies 14 replies
  • Views 1249 views
I think that when somebody installs v6 alongside v5 that v6 should run
exclusively and not use v5 libraries.
I say this because when I installed v6 it wanted to use my old v5 libraries.
I copied my projects and libraries to entirely new directories so that my
old ones would not get fouled up and I made the appropriate changes to the
control panel "Options Directories", but Eagle IGNORED my changes that
pointed to the v6 libraries. Instead of using my v6 libraries, Eagle v6
continued to use my old v5 libraries from a non-specified directory.
Fortunately I realized that my old libraries were in use and proceeded to
fix the problem.
"Use -*" (enter) and then "Use *" took care of the problem, but WHY should
that rigamarole be necessary??.
This is not a suggestion so much as it is a bug report. It's an accident
waiting to happen. I remember the exact thing happening as I upgraded from
v4 to v5.
    Am 30.12.2011 23:54, schrieb Brett Holden:
    v4 to v5.
    This problem happens with LOTS of people and EVERY major program update
    since YEARS (and also with every OTHER program on earth). In most cases,
    the user KNOWS that one may not overwrite old projects that still need
    to be edited with the older version, but sometimes the phone rings,
    something else happens and voila! you forget and have ruined your old
    files by just accidentally pressing CTRL+S. Too bad! (And yes, I myself
    was also swearing wildly once when doing an update from 4 to 5. Luckily,
    I had some backups and only had to throw three hours of work in the bin)
    This is again a case of bad GUI in case of problems: Here, the user
    SHOULD be notified, but isn't, probably resulting in problems. There are
    several simple possibilities to get this done properly (and lots of
    programs use at least the following point 1):
      1. EAGLE just KNOWS the version with which a newly opened file was
         previously created. And it knows its OWN version. And CadSoft
         KNOWS between which versions (even minor version changes) the
         data structure was changed or expanded. Therefore,
          - if there is a FILE data structure change between the saved
            file and the current EAGLE version, the user is notified
            with a dialog box like: 'This file was created with an older
            version of EAGLE. If you change and save it, you might not be
            able to reopen it with the old EAGLE version. Proceed with
            the file loading? '.
         THAT is quite easy to do, BUT has the problem that the user
         might easily FORGET this message during viewing. Accidentally
         pressing CTRL+S does STILL ruin editability with older versions.
      2. To circumvent this, a similar question could be asked AGAIN
         when the user wants to SAVE the file ('Do you really want to
         overwrite the existing file? Reopening it with older EAGLE
         versions might not be possible afterwards. '). Yes,
         this MIGHT be a nuisance, but this save warning is displayed
         only ONCE per file IF there might be a version problem. After
         the file has REALLY been saved with the new version, these
         questions will cease completely until a new (not downward-
         compatible) version is used. That should be OK (at least in
         MY opinion).
      3. Some other programs use different schemes, which I myself do NOT
         like much:
          - In case file versions differ, the user is informed during
            file loading (as stated above). To prevent accidental
            overwrites, the file is opened write-protected. Before
            saving it again, write-protection must be disabled manually
            in some file option dialog. [Disadvantage: There must be
            this write-protection option somewhere]
            overwrites, the file is opened like a NEW file (without
            proper file name), so just saving does NOT work, because the
            user is ALWAYS asked for a new file name. [Disadvantage:
            The user MUST enter a file name. This needs quite some
            typing, and one MIGHT even have forgotten the name in the
            meantime]
    Therefore, the combination of (1) and (2) should make version problems a
    thing of the past. And for the guys who really HATE to be asked such
    questions, why not implement my suggestion from the post 'EAGLE GUI (7):
    Unnerving failure behaviour' and put a 'Don't show this message again'
    checkbox in the question dialog (2)?
    The above is VERY easy to implement and protects the user from ACCIDENTS
    (this is what a good GUI should do). Of course the new EAGLE version
    would STILL use the old libraries and not its own ones. But this CAN be
    circumvented with the '-U' switch. If the user wants to run different
    EAGLE versions in paralled, put some information about that in the
    manual. This way, newbies cannot ACCIDENTALLY overwrite their projects,
    and experts can take parallel-install information from the manual. I
    cannot tell whether there would still be awkward problems when using
    PROJECTS - I just HATE the behaviour with projects due its multiple
    drawbacks, and therefore our institute doesn't use them...
    Andreas Weidner
    Am 04.01.2012 06:52, schrieb Grzegorz Zalot:
    Hello Joern Paschedag !:
    >> The -U parameter was imo created during Ver.5 testing. I didn't know how
    >> to use this parameter by that time but got an answer from cadsoft that
    >> it "sets" a new path for the "eaglerc.usr" file. To test that I gave it
    >> a new name too and that worked. image
    >> So since that time I use somethimg like "-U F:\Eagle-6.0.2\
    >> eaglerc602.usr" to place the file in the eagle Ver.6 dirctory.
    >> Same goes for my version 5.
    Brrrrrr, workaround again ....
    Yes, but I have to run 3 Versions of eagle, 4, 5 and 6 and so this is at
    least a little way out...
    >> Warren Brayshaw has explained that more detailed.
    >> So if users place the -U parameter with "my" extention into the
    >> properties of the launcher they should change the name of the
    >> eaglerc.usr file first before starting eagle, otherwise they run against
    >> the wall again.
    Exactly here is the problem.
    BR
    Well one must know what one is doing (hopefully) image
    I have to watch out carefully since some clients send version 4.x files
    and insist of return in this version.
    Right now I'm working still with v5, because of the many reported
    troubles in v6, which was imo released too early.
    If there is time I test with v6 or try to follow reports but so far I
    had none of the so many reported crashes on my windows xp.
    Unfortunately many people reporting errors witout mention the machine
    and software they use. That makes it even more difficult for cadsoft to
    locate errors.
    Sorry but I am drifting OT.
    Joern Paschedag
    the wall again.
    BR
    Grzegorz Zalot
    complex ltd.
    office tel/fax : +48 32 2505840
    mobil : +48 501 301515
    http://www.complex.org.pl/
    Am 03.01.2012 07:56, schrieb Grzegorz Zalot:
    Hello Brett Holden !:
    >> libraries.
    The problem is really primitive and ... IMHO stupid. In fact all EAGLE
    instances use THE SAME eaglerc.usr file !!!!! Of course in v5 the libs
    are in v5 subfolders, in v6 - sure not the same. Of course the danger to
    make unwanted update of the libs is really high.
    I am afraid this stupis behaviour is not aa incident ... I guess CadCoft
    want to push more peopple to buy new v6. Why ? Because changing the name
    of the usr file is really primitive.
    My suggestion : if CadSoft still want to use same name of the usr file
    we have to use some workaround, f.i. batch file or ... use an hex editor
    and change the name of the usr file !!!! This is 1-2 minutes time and
    works perfectly.
    IMHo this is really a stupid problem ... and sure totally unnecessary.
    best regards
    Happy New Year everyone image
    how to use this parameter by that time but got an answer from cadsoft
    that it "sets" a new path for the "eaglerc.usr" file. To test that I
    gave it a new name too and that worked. image
    the wall again.
    Joern Paschedag
    works perfectly.
    best regards
    Grzegorz Zalot
    complex ltd.
    "Warren Brayshaw" <warrenbrayshaw@paradise.net.nz> wrote in message
    news:jdt3r8$d95$1@cheetah.cadsoft.de...
    Brett Holden wrote:
    >> ..............Here is text from the manual, page 113:
    >> "It is possible to start EAGLE with the command line option -U which
    >> can be used to define the location of the eaglerc file."
    >> That does not explain anything to me. I can't use -U if I don't know
    >> how. If this goes on much longer I will feel obliged to re-ask this
    >> question in the support forum, but maybe somebody can answer me here
    >> to get this over with:
    >> What is the proper syntax and application for starting Eagle with the
    >> -U parameter? (I'm using Windows XP.)
    Hi Brett
    Mario's reference is good.
    Some further clarification.
    1) When you use the  -U option you can name the 'user file' anything as it
    does then not have to remain as eaglerc.usr. In the example Richard
    provided
    it is named 'myeaglerc.usr'.
    2) If there are spaces in your path to the file then double quotes are
    needed. I launch from a desktop icon so modified its target (in
    properties)
    so that it contains the -U option and location of the eaglerc.usr file.
    As I have spaces here is my path.
    "C:\Documents and Settings\Warren\NewEagle2\bin\eagle.exe" -U"C:\Documents
    and Settings\Warren\NewEagle2\eaglerc.usr"
    3) Note there is no space after the U
    4)If you have multiple Eagle version installs, double clicking a design
    file
    outside of Eagle cannot be used to launch Eagle as only one version of
    Eagle
    can be associated with the file type.  You can set up Windows so that if
    you
    right click on the file (viewed in, say, explorer) then the context menu
    lists the multiple Eagle versions you have set up. In this way  you can
    launch the appropriate Eagle version from the file but I have not found a
    way to make none of them the default. You want no defaults as a double
    click, in error, on the file may launch the wrong Eagle version. It is
    best
    to disable file associations from brd, sch,  lib, usr files.
    Hope this helps
    Warren
    news.cadsoft.de
    That's it, Warren.
    I thought Mario's references would be the fix but I was still getting kicked
    in the teeth with various error messages, either trying to use the RUN box,
    or trying to launch from a desktop icon with modified icon target
    properties.
    So, thank you for that explicit example, that is exactly what I needed. I
    was having trouble because there is a space in my directory path and I had
    forgotten the need for double quotes.
    The -U option is working now (and no thanks to Cadsoft's documentation).
    Cadsoft apparently expects somebody using their product to be a computer
    guru, or else suffer.
    Thank you to all who responded.
    Hi Brett
    does then not have to remain as eaglerc.usr. In the example Richard provided
    needed. I launch from a desktop icon so modified its target (in properties)
    4)If you have multiple Eagle version installs, double clicking a design file
    outside of Eagle cannot be used to launch Eagle as only one version of Eagle
    can be associated with the file type.  You can set up Windows so that if you
    click, in error, on the file may launch the wrong Eagle version. It is best
    Hope this helps
    Warren
    news.cadsoft.de
    "MarioS" <noreply-77933@element14.com> wrote in message
    news:610995789.1241325512868348.JavaMail.jive@flmspu-csapp-02.premierfarnell.com...
    Please, see this:
    http://www.eaglecentral.ca/forums/index.php?t=rview&goto=135889&th=42936
    Saludos y Felices Fiestas!
    Aiieee!
    Mucho gracias , señor.
    About 'command line option -U', please, see this:
    news:jdo4aj$c3$1@cheetah.cadsoft.de...
    Brett Holden wrote:
    >> Yup I originally had problem with only the wrong libraries being
    >> used. Now I can't seem to get Eagle to use the v6 project folders I
    >> established. It wants to open the old schematic files and I don't see
    >> an obvious fix...........
    Continuing on from what has be written previously you may still have
    problems caused by eaglerc.usr
    eaglerc.usr  file also contains the directory paths and when you launch
    Eagle it sets those paths into Control Panel/Options/Directories.
    Have you set up your v5 and v6 versions to launch with the -U option to
    specify exactly where the eaglerc.usr for each version resides?
    If not each installed version of Eagle will forever be entangled as you
    swap
    between them due to a single eaglerc.usr being used.
    Once you have established a separate eaglerc.usr for each version  you can
    then proceed to clean up the eaglerc.usr of each of the versions if need
    be.
    I would progress this way.
    1) Launch an Eagle version
    2)Ensure no Project is selected
    3)Check and modify Control Panel/Options/Directories.
    3) Save all
    4) Control Panel / Refresh.
    eaglerc.usr should now be correct for that version you are viewing.
    Then, for v6 and as said previously, as you load a project from a previous
    version for the 1st time you have to  "Use -*" (enter) and then
    "Use*" to get rid of the library paths to the libraries of the previous
    versions (contained in the eagle.epf file you also copied across) and only
    present the libraries as defined in the paths in Control
    Others reading this and who have not followed the thread fully should be
    aware that you should not just commence opening v5 projects with v6. After
    the obligatory 'backup', replicate your v5 project (a folder with all its
    files)  into the v6 project folder and work from that copy as the
    eagle.epf
    file of that project needs to be personalised for v6.
    All the best
    Warren
    news.cadsoft.de
    Thanks Warren, Joern.
    I deleted the Eaglerc.usr file and reloaded and my problems with using ver5
    files disappeared. But I would like to know how the -U parameter is
    implemented.
    I found in the manual (and update notes) where there is such a thing but I
    can find no instruction how to use it.
    "It is possible to start EAGLE with the command line option -U which can be
    That does not explain anything to me. I can't use -U if I don't know how.
    If this goes on much longer I will feel obliged to re-ask this question in
    the support forum, but maybe somebody can answer me here to get this over
    with:
    What is the proper syntax and application for starting Eagle with the -U
