EAGLE User Support (English) How to copy a sch page from one design to another design
  • Subscribers 187 subscribers
  • Views 795 views
  • copy
  • eagle
  • sch
  • ulp
  • page
  • schematic
I wanted to copy a schematic page from one design to another, is there ULP anyone has?
    I should have explained that the lengthy process I detailed is only
    necessary if you need to copy one design to another AND you have PCB layout
    in the object design that you need to preserve.
    "Brett Holden" <bretth2o@bellsouth.net> wrote in message
    news:jelg2t$hud$1@cheetah.cadsoft.de...
    "wests_gtp" <noreply-81522@element14.com> wrote in message
    news:643411937.1241326291866019.JavaMail.jive@flcspu-csapp-01.premierfarnell.com...
    >> It didnt work.....
    I'm not surprised.
    For my explanation, the object is what you are copying, and target is what
    you are copying to:
    In V5, to copy one schematic to another simply Group the object schematic,
    Cut, open the target schematic, and Paste. Again: Group, Cut, Paste. The
    process is done with one instance of Eagle and you can only have one
    design open at a time .
    But... I am assuming that you also need to copy the PCB components along
    with the schematic?
    If so you should first run the renumber-sheet.ulp on the object schematic.
    Start the designators at, say 200, so that those designators will not
    overlap the designators of the target schematic. Save.
    Close out the PCB. Then, Group, Cut, open the target schematic and Paste
    just like the first example. Save.
    Now go back to the object project and group the PCB, Cut. Now open the
    target project, and close the schematic so only the target PCB is open.
    Paste the object into it. Save.
    Now from the target PCB (with the object having been pasted into it) you
    should be able to open the  target schematic and have everything be
    consistent.
    I hope I explained everything correctly.
    If it sounds tricky, well, it must be done correctly or you will wind up
    with a lot of inconsistencies. The component reference designators in the
    two schematics must not be the same, that's why you use Renumber-Sheet.ulp
    starting at a high number.
    It didnt work.....
    I'm not surprised.
    you are copying to:
    process is done with one instance of Eagle and you can only have one design
    open at a time .
    with the schematic?
    consistent.
    It didnt work.....
    5.11.0  - I found an import export ULP that I am going to try out.
    news:510088850.1741326208055354.JavaMail.jive@flcspu-csapp-01.premierfarnell.com...
    >anyone has?
    What version?
