EAGLE User Support (English) Connection after copy and paste
  • Subscribers 187 subscribers
  • Views 178 views
Hello again,
another point I can't understand. I searched in the manual without found
anything.
When I use the copy command and place a component on pins EAGLE moves
the component so it doesn't connect to them. Why?
I have to move again the component in order to get the connections.
The same applies if I use the paste command. In this case the component
will be placed where I want but the connections are not performed.
This is more dangerous because you don't see the problem.
What are the advantages of those behaviors?
Marco
