EAGLE User Support (English) Notes on schematics ?
  • Replies 7 replies
  • Views 1518 views
Many years ago (far too many), back in the days of vellum or mylar with the
plastic lead, we used to make a point of putting note "clouds" on
schematics (address maps, port maps, wave form comments etc) that were very
handy for anyone later using the schematics for debugging etc.  I miss
those days (somewhat) - what is the best way these days to put notes for
people on the schematics ?  Put stuff on the documentation layer (tables
etc) or how do most folks do it ?  Snooping through the manual and the
online tutorials, I have not seen any mention of that.
Thanks !
mike
    Yep - bit of a different mind set (and who knows why "cut" = "copy"!).
    Like in Sony Vegas (video editor) - if you want to adjust the audio track
    volume you will go nuts trying to find that in the help files.  The answer
    is you apply an "envelope" to the track which you can then manipulate.
    Would have been nice if the index had "volume - see envelope" or
    something.
    mikey
    gpsmikey wrote on Fri, 20 January 2012 16:05
    I have learned that what seems "intuitively obvious" in Eagle may not
    be ... like not using "wire" to connect things in a schematic image
    You mean it's not obvious you use WIRE to draw lines, except of course when
    those lines represent wires!?
    Sounds good to me - thanks for the feedback -- I have learned that what
    seems "intuitively obvious" in Eagle may not be ... like not using "wire"
    mikey
    DOC is fine too.  You can use whatever you want.  I tend to use INFO, but
    that's probably just because that's what I did long ago.
    OK, so use the info (97) not the Doc (48) layer in general for that sort of
    thing ?  I will go with that plan.  Turn on the appropriate layers when
    printing so I have the "INFO" for my notes (makes life easier).  Thanks.
    mikey
    That's generally what the INFO layer is for.
