EAGLE User Support (English) Eagle crashes when mirroring schematic symbol
  • Views 397 views
I am using win XP and v6 lite (currently v6.0.2 beta) and have nothing but
trouble. Probably my worst problem is that Eagle crashes when I mirror a
symbol that is connected directly to ground.
If I have a vertically oriented symbol touching a ground symbol, then select
the symbol (L-click), middle click to mirror, then L-click again to
de-select, Eagle crashes immediately.
Also, if the  component touching a ground, all I have to do is to click the
mirror icon then click the component, and Eagle crashes immediately.
So far, I see this happening for verticle resistors, capacitors, and diodes.
All I need to create the problem is one ground and one other schematic
symbol.
Does anybody else see this happening and can anybody tell me what to do
about it - besides never mirroring any vertically oriented component that
touches a ground symbol?
    symbol.
    Hi Brett,
    I have forwarded the issue to our developers I can recreate it here.
    Best Regards,
    Jorge
    >> nothing but trouble. Probably my worst problem is that Eagle crashes
    >> when I mirror a symbol that is connected directly to ground.
    >> then select the symbol (L-click), middle click to mirror, then
    >> L-click again to de-select, Eagle crashes immediately.
    >> click the mirror icon then click the component, and Eagle crashes
    >> immediately.
    >> diodes. All I need to create the problem is one ground and one other
    >> schematic symbol.
    >> do about it - besides never mirroring any vertically oriented
    >> component that touches a ground symbol?
    Hi Brett,
    Upgrade to V6.1.It's the latest bugfix release and has many
    corrections.
    Best Regards,
    Am I missing something here.
    A  release (6.1) should be the functionally the same as the last beta which
    was 6.0.2
    Warren
    news.cadsoft.de
    symbol.
    Hi Brett,
    Upgrade to V6.1.It's the latest bugfix release and has many corrections.
    Best Regards,
