EAGLE User Support (English) Gerber output - how can I retin the 'la yer's
  • Views 507 views
It seems that when I use Eagle to export to gerber (using the std cam
gerber274x ...or any other gerber cam listed there), that all the eagle
layers get 'flattened' into one ...this is real a hassle for me.
I like to mill my pcb...so I use the gerbers as import files into another
cam program
The cam program I use (cambam) can create seperate 'drawing layers' for
each gerber layer....but becuase eagle flattens the layers when
exporting,everything inn the gerber therefore gets imported into one
layer.... I then have to spend ages reconstructing all the drawing objects
into layers again within cambam.
Are there any gerber cam experts that can advise how I can get Eagle to
export to gerber but retaining the layers so that cambam will accept.
I've attached a (non Eagle produced) gerber file in the format that cambam
reads the seperate layers.
opto_input.pcb.output_back.gbr.zip
    hi paul/jorge,
    yes thanks...i found the sparkfun cam job & worked out how to extract all
    thE eagle layers as individual gerber files - but that's not really want i
    seek (becuase that would then need me to import each gerber file into
    camba,m one at a time)
    What I'm after is a way of exporting to ONE gerber all the eagle layers I
    highlight in the layer selection window ....but for eagle to export in a
    way that allows another 3rd party gerber file reader or CAM program to then
    extract each gerber layer out to an individual drawing layer.
    On 1/27/2012 3:42 PM, Robert Smith wrote:
    hi paul/jorge,
    yes thanks...i found the sparkfun cam job&  worked out how to extract all
    Hi Robert,
    To the best of my knowledge that's not possible in EAGLE. What you could
    do is zip all of the gerber files together and possibly give that zip
    file to your cambam software.
    hth,
    Jorge Garcia
    cam program
    I am not sure of how you need the data. You can go to the job tabs in
    the cam process and only include layer 1 for the traces. Duplicate that
    tab and put pads on it and so forth.
    Have you looked at the ULP's for milling machines? I think it generates
    the contours that mill away the copper.
    Paul R.
    cam program
    Hi Robert,
    You need to use a cam job. If the board is a simple two layer board you
    can use the gerb274x.cam job that's included with EAGLE. Here's the
    procedure.
    1. In your board editor click the CAM processor icon.
    2. Left-click on the File menu(not the file button that is near the
    middle of the CAM dialog) -> Open -> Job.
    3. Select the gerb274x.cam file and open it.
    4. You'll now see tabs along the top edge of the CAM processor under the
    Pull down menus. Each tab is a seperate gerber file, so this CAM job
    will generate 5 useful files and one summary file(gpi extension).
    5. Left-Click on Process Job to generate the gerbers. The gerbers will
    be in the same folder your board file is in.
    6. You may also need to generate a drill file. Left-click File-> Open->
    Job. This time select excellon.cam and open it.
    7. This one is also ready to go, left click the Process job button.
    For more info on how this all works see chapter 9 of the EAGLE manual.
    hth,
    Jorge Garcia
