EAGLE User Support (English) Vias without Thermals
  • Views 341 views
I know this has been asked before , but I cannot locate a thread with an
answer.
I have Eagle 4.16,  what is the easiest way to eliminate the thermals
around specific vias. ( not all vias)
After some though, strategically placed polygons would make sense (and
ignore the drc errors)
any other suggestions?
Martin
    "Warren Brayshaw" <warrenbrayshaw@paradise.net.nz> wrote in message
    news:jfvtmm$tq$1@cheetah.cadsoft.de...
    There is not a DRC error if you ensure the polygon placed over the via
    has
    the same name as the via.
    Also ensure that this smaller polygon overlaying the via has its
    'Thermals'
    property turned off.
    Worked for me and a pleasure to use 4.16 again.
    See image. The DRC has been run and shows an intended drill size error
    for
    the lower via but no errors occur in the area of the upper via.
    Warren
    Web access to CadSoft support forums at www.eaglecentral.ca.  Where
    the CadSoft EAGLE community meets.
    Excellent, That works the way I had thought it does.
    Cheers
    There is not a DRC error if you ensure the polygon placed over the via has
    Also ensure that this smaller polygon overlaying the via has its 'Thermals'
    See image. The DRC has been run and shows an intended drill size error for
    Warren
