EAGLE User Support (English) How to make large pads?
  • Views 278 views
SMD111
SMD111 over 14 years ago
I have no idea why the size of a pad drill is limited to 1/8" in Eagle. This
is not enough even for a #4 screw.
Please let me know how to overcome this limitation.
Thank you.
    Eagle. This is not enough even for a #4 screw.
    Thank you.
    The drill size limit is just over 1/2 "
    You can add your own drill sizes to the offered selection
    Select CHANGE and then DRILL
    At the bottom of the list you will see '...' so click that and enter your
    desired size.
    If you need further guidence see the Tutorial pdf in the DOC folder of your
    install and read the section  "Changing Line Width"
    Warren
    news.cadsoft.de
