EAGLE User Support (English) Extremely repetitive script
  • Views 235 views
So I've been tasked with the job of designing a circuit board with 10240 pads on it.  I can split it up into 10 sections of 1024 pads, so let's assume I only need to make 1024 pads since copying that section and moving it into the appropriate positions I need is pretty simple for this geometry.  I've been looking into scripting this one out since I don't feel like spending days and days doing this, but I've yet to find an easy way to make loops in .scr files.  ULP's I know you can make loops in, but I'm unsure (if this is even the way to do it) of how one would send the appropriate arguments to the appropriate .scr file or how to even run a .scr file from a ULP (I know you can run a ULP from a .scr, but I'm not sure it works the other way).  Am I missing something really obvious?
  • dukepro
    dukepro over 14 years ago
    You could write your program in any number of other languages.  C,
    Basic, Perl, etc.  You're not stuck with ULP.
    But if you do choose to use ULP, you want to start with an output statement:
    output("myfile.scr") {
    Every print inside the braces will be written to the specified file.
    Next, inside the braces place the code that will iterate through each
    pad.  perhaps something like:
        int block, xpad, ypad;
        for (block = 0; block < 10; ++block) {
            for (xpad = 0; xpad < 32; ++xpad) {
                for (ypad = 0; ypad < 32; ++ypad) {
                    // calculate x and y coordinates of this pad
                    // Emit to the script file
                    printf("pad (%f %f);\n", xcoord, ycoord);
    Then when everything is done, and you're outside of your output block,
    exit with a string argument, where the argument is the name of the
    script file to execute:
        exit("myfile.scr");
    The precise syntax may be off a bit, but that's the outline.
    As I mentioned above, it might be easier to write a C program for this,
    and just redirect the output to your script file.
    Enjoy,
        - Chuck
