EAGLE User Support (English) v5.11 incompatibility with earlier versions
  • Views 703 views
I want to update a board created in the early days of ver 5 with a new
analog front end.  I have drawn the new front end in ver 5.11.  I can open
the old schematic and remove the old front end.  I can open the new v5.11
front end, copy it and paste it into the old schematic.  It looks perfect
in the schematic view but the layout view shows the new and old components
but with 50% of the component linkages (wires) missing.  The board passes
the ERC with no errors reported but visually it is a shambles.
What is the procedure to update an older board and bring it into 5.11?
thank you
Brian
    Thanks Warren.
    I think the problem is I was trying to load new ver 5.11 parts back into a
    ver 5.early schematic and layout.  I think I have it now.  I must first
    load the new 5.11 parts then add older 5.xx parts.  The new 5.11 is
    backwards compatible but the old 5.early cannot be forward compatible.
    Thanks for you speedy reply.
    Brian
    open the old schematic and remove the old front end.  I can open the
    new v5.11 front end, copy it and paste it into the old schematic.  It
    looks perfect in the schematic view but the layout view shows the new
    and old components but with 50% of the component linkages (wires)
    missing.  The board passes the ERC with no errors reported but
    Hi Brian
    I would first check that the new front end nets are the same as the net
    names of the old schematic where they connect.
    They may look connected but maybe not. Do a SHOW in the area of the
    connections or move a section and see if the nets are connected.
    Maybe a  RATSNEST in the board editor will reveal the missing airwires.
    When you removed the old front end from the old schematic, was the board
    also open?
    Does the schematic ERC reveal no errors?
    Warren
    news.cadsoft.de
