EAGLE User Support (English) Library compatibility between 6.1 and 5.11
  • Views 1182 views
I'm starting to work with a guy who's building libraries for me; I just
tried opening one of his libraries for the first time, and I got the
message "Invalid data in file ".
I looked at his library file, which is tagged as being created by Eagle
version 6.1.  I'm using 5.11, and don't really want to change.  Should
this be working?
I'm also on a Linux machine, and he's on a Windows machine -- could this
be the problem?
My liberal friends think I'm a conservative kook.
My conservative friends think I'm a liberal kook.
Why am I not happy that they have found common ground?
Tim Wescott, Communications, Control, Circuits & Software
http://www.wescottdesign.com
    Well, editing the XML file solved the problem. There was more parts with
    gate="". I guess 6.1 can't handle these kind of parts. At least the library
    opened now...
    I just tried opening a 5.11 library with 6.1. I got an error message (and
    the library didn't open):
    EAGLE update report
    Date: 9.2.2012 8:03:19
    File: C:/Program Files/EAGLE-6.1.0/lbr/omat.lbr
    An error occurred while parsing the intermediate XML file.
    The XML file has been loaded into a text editor window as
    C:/Program Files/EAGLE-6.1.0/lbr/omat.rpt.lbr
    Warning(s):
    line 10717: invalid value '' for attribute 'name' in tag
    This is my own part library and there is no way I'd do the parts all over
    again in 6.1. Is this error fixable? Thanks!
    Am 06.02.2012 23:47, schrieb Tim Wescott:
    >>> message "Invalid data in file Warren
    Man, I just can't say how happy it makes me to hear that.  At least --
    not without using words my mother told me not to use.
    You still could try to export the v6 libs and import them into new v5
    libs. Anyway some errors will be reported, but perhaps not all the work
    is lost image
    Joern Paschedag
    >> message "Invalid data in file  this be the problem?
    Libraries are not compatible.
    I'm beginning to sound like a stuck record but keep away from v6 for
    now. Far to many issues to entertain using it.
    Warren
    warrenbrayshaw wrote on Mon, 06 February 2012 17:07
    just tried opening one of his libraries for the first time, and I
    got
    the message "Invalid data in file <filename>".
    Eagle version 6.1.  I'm using 5.11, and don't really want to
    change.
    Should this be working?
    could
    now.
    But this isn't an issue with a "bug" so when the issues you are referring
    to this issue will still be there.  EAGLE V6 will store any file it saves
    in V6 format.  EAGLE V5 cannot read this.  The confusion is that CadSoft
    didn't change the file extension.
    What should have been done is the new extension becomes .schx, .pcbx, and
    lbrx for instance to indicate the XML format.  Then files wouldn't be
    overwritten which is part of the problem.
    Being able to "save as" V5 format would be very helpful for design houses
    like us where we could use one tool and save out different format.  Until
    that is available you'll have to ensure that the library is provided in V5
    format if you intend to use it in a V5 design.
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    just tried opening one of his libraries for the first time, and I got
    Eagle version 6.1.  I'm using 5.11, and don't really want to change.
    I'm beginning to sound like a stuck record but keep away from v6 for now.
    Warren
    news.cadsoft.de
