EAGLE User Support (English) TEXT command does not match HELP
  • Subscribers 187 subscribers
  • Views 116 views
The HELP for TEXT  states the following
Special Characters
If the text contains several successive blanks or a semicolon, the whole
string has to be enclosed in single quotes.
If the text contains single quotes then each one itself has to be enclosed
in single quotes.
If apostrophes are required in the text, each must be enclosed in single
quotes.
While confirming this I observed odd results.
The following is observed when using the command line.  I will use a carat
(^) to indicate a space character.
abc^^xyz   results in abcxyz
'abc^^xyz ' results in abc^^xyz
abc'xyz results in abc'xyz
'abc'xyz' results in abc^xyz'
abc'''xyz results in abc'''xyz
'abc'''xyz' results in  abc'^xyz'
abc'''^xyz results in abc'^^^xyz
'abc'''^xyz' results in abc'^xyz'
A change appears to be required..
v5.12
Warren
news.cadsoft.de
