EAGLE User Support (English) How to use Polygon fill
  • Views 344 views
I have a small board, fairly dense, double sided approx 22 x 46 mm with 135
wires and all SMD except for battery pads and signal i/o pads.  EAGLE 5.11
will not allow a ground copper pour.
I can route the board 100% but when I try to do a polygon gnd with orphans
on or off it fails to pour and I get messages like Optimise6:80.3%
finished.  Polygons may have fallen apart.
I have tried polygons before and after routing always with the same
results.
Has anyone got a foolproof check list of what settings to use and the order
to do it in?
thanks in advance
Brian
    with 135 wires and all SMD except for battery pads and signal i/o
    pads.  EAGLE 5.11 will not allow a ground copper pour.
    orphans on or off it fails to pour and I get messages like
    Optimise6:80.3% finished.  Polygons may have fallen apart.
    results.
    order to do it in?
    thanks in advance
    Brian
    Attach your 100% routed board file that fails to take the polygon fill.
    Someone should be able to spot what is tripping it up
    Warren
    news.cadsoft.de
