EAGLE User Support (English) bug regarding text logo in library and flood-fill
  • Replies 7 replies
  • Subscribers 187 subscribers
  • Views 1692 views
  • logo
  • flood
  • bug
  • text
I have demonstrated the bug in this video, please watch it in 1280x720 and full screen
http://www.youtube.com/watch?v=odne9gdBqfY
This video is unavailable.
    On 2/26/2012 10:30 PM, frank26080115 wrote:
    it's keeping away from the text on the bottom layer
    that is definitely not my intention
    my video clearly demonstrated that it's indeed a serious bug
    Hi Frank,
    Turns out the bug has already been corrected in the latest beta 6.1.2.
    Thanks for your feedback.
    Best Regards,
    Jorge Garcia
    Hi Frank
    Can you tell me the name of the software you used to make the video.
    Warren--
    news.cadsoft.de
    I have notified our developers of the bug, and forwarded your link to
    them. Thanks for the info, these bug reports have proven to be
    instrumental in getting EAGLE back to it's normal robustness. Thank you
    again for continuing to use EAGLE.
    Best Regards,
    Jorge Garcia
    Cadsoft Support
    Frank Zhao wrote:
    Hi Warren
    The reason the tRestrict layer appears to have not taken effect is
    because the flood fill polygon had isolate set to 0, also orphan was
    enabled. I prefer to use tRestrict wires to completely enclose an
    area instead of rectangles or polygons because I don't want the area
    to appear shaded. If this is not a recommended practice, then let me
    know.
    Regardless of that, I made my point. I hope this gets fixed.
    Have a look at the actual logo
    http://i.imgur.com/SivO9.png
    The logo image looks unconventional to me.
    The top flood fill has an edge shape that mimics a clearance from the text
    on the bottom layer. It may be what you intended image
    So what object is the top flood fill keeping away from?
    Warren
    news.cadsoft.de
    Hi Warren
    The reason the tRestrict layer appears to have not taken effect is because the flood fill polygon had isolate set to 0, also orphan was enabled. I prefer to use tRestrict wires to completely enclose an area instead of rectangles or polygons because I don't want the area to appear shaded. If this is not a recommended practice, then let me know.
    I agree there is  a defect that  needs correcting as the behaviour should be
    the same for the Top and Bottom layers.
    I wish to point out an error with your package design.
    You drew a rectangle around your text using a zero width wire, placing it on
    the tRestrict layer.
    That had no effect as the area under the zero width wire has no area. The
    ratsnests you performed revelaed this.
    Had you wanted the copper text within a  rectangle clear of copper you
    should have formed the rectangle with the RECTANGLE tool
    HTH
    Warren
    news.cadsoft.de
