EAGLE User Support (English) Negative text on silkscreen
  • Replies 16 replies
  • Views 3593 views
Hello everybody.
Is there  a way (perhaps a ULP) for creating negative text on
silkscreen ? I know it can be done by importing a .bmp file but
i wonder if there is a more elegant way.
Michail Kyriakakis
    Jorge Garcia wrote:
    On 2/25/2012 3:55 PM, Warren Brayshaw wrote:
    >> There is a ULP called negasilk.ulp by Christian Bohrer
    >> It exists as an attachment to a posting in the eagle.support.eng
    >> forum The easiest way to locate it is to use the eagle central portal
    >> http://www.eaglecentral.ca/forums/ and search for negasilk
    >> It's in the topic "silkscreen inverse text"
    >> Warren
    The negasilk ULP has also been uploaded to the online repository at
    www.cadsoftusa.com-> Downloads-> User Language Programs. It's been
    submitted should show up on the list in a day or two.
    Best Regards,
    Jorge Garcia
    Cadsoft Support
    Jorge
    Did you get permission from the author to upload it to the CadSoft site?
    Correct me if I'm wrong. The terms of use of the CadSoft site are, if you
    upload something there the IP rights are transferred/gifted to CadSoft.
    There are no such terms for the Newsgroup forum and some authors elect to
    post content there but purposly avoid uploading to the website to prevent
    gifting the IP rights to CadSoft.
    It may pay to check out your action.
    Warren
    news.cadsoft.de
    It exists as an attachment to a posting in the eagle.support.eng forum
    Warren
    Best Regards,
    Jorge Garcia
    Cadsoft Support
    Michael Kyriakakis wrote:
    >>Hello everybody.
    Warren
    Thank you all for the suggestions.
    The negasilk.ulp did the job fine.
    Michael Kyriakakis
    Hello everybody.
    Warren
    news.cadsoft.de
    Hello Michael,
    Hmmm, a polygon in separate signal_layer with a zero-width text and
    print simultaneously with silkscreen ?
    Unfortunately for inner layers there is still no restrict possible.
    BMP converted to lines/points is of course possible as well.
    BR
    Grzegorz Zalot
    complex ltd.
    office tel/fax : +48 32 2505840
    mobil : +48 501 301515
    On 2/25/2012 9:59 AM, Michael Kyriakakis wrote:
    Hello everybody.
    Michail Kyriakakis
    Have you tried putting it on its own layer and inverting it in the cam
    processor?
