EAGLE User Support (English) Negative text on silkscreen
  • Replies 16 replies
  • Views 3582 views
Hello everybody.
Is there  a way (perhaps a ULP) for creating negative text on
silkscreen ? I know it can be done by importing a .bmp file but
i wonder if there is a more elegant way.
Michail Kyriakakis
    autodeskguest over 14 years ago
    "cicloide" <noreply-100989@element14.com> a écrit dans le message de news:
    88265975.19231334771341532.JavaMail.jive@flcspu-csapp-01.premierfarnell.com...
    Hi guys,
    I wasn't able to make this ULP to work in Eagle v.6.1.0. Did you try your script with recent
    versions of Eagle? I followed these instructions:
    1. Open a new board
    2. Draw a polygon on the top layer
    3. Change to 8 mils the width of the polygon
    4. Choose the layer 41 (tRestrict) and write or draw what you want
    inside the polygon area
    5. Run negasilk.ulp (a script is generated)
    Now, you can:
    Either run the script in the final board on the layer of your choice (21) or best, run the script
    in a library for using the result in the board as a component
    The scripts that the ULP generates contains only a couple of lines and
    not as many as the example that was inside the zip file. Do you know
    what could be causing the problem?
    Thank you.
    I've just tried negasilk in V6.2.0 and all seems to work correctly
    Maybe your problem is that you forget to run RATSNEST before to launch negasilk.ulp ?
    I have to add this:
    If you write a texte in the layer 41, you have to change the font to "vector" and check the Orphans
    in the polygon properties box.
    You can also reduce the width of the polygon for a best filling.
    Christian Bohrer
    Hi guys,
    I wasn't able to make this ULP to work in Eagle v.6.1.0. Did you try your script with recent versions of Eagle? I  followed these instructions:
    1. Open a new board
    Now, you can:
    Either run the script in the final board on the layer of your choice  (21) or best, run the script in a library for using the result in the  board as a component
    Thank you.
    On 2/29/2012 2:55 AM, Christian Bohrer wrote:
    importexport.zip
    pcb-service.ulp
    gencad_131.ulp
    Best Regards,
    Christian Bohrer
    Hi Christian,
    The two sites mirror each other, I was able to find importexport.zip and
    pcb-service.ulp on the new site as expected, however I couldn't find
    gencad_131.ulp. I let our webmaster know and see what happens.
    Best Regards,
    Jorge Garcia
    Jorge Garcia wrote:
    On 2/28/2012 4:37 PM, Warren Brayshaw wrote:
    >> Hi Jorge
    >> Actually, I was right about the statement existing , but wrong in the
    >> detail. My apologies.
    >>   From http://www.cadsoftusa.com/forums/guidelines/?language=en
    >> QUOTE
    >> 14. These are CadSoft news groups
    >> By participating, you grant to CadSoft the unrestricted right to use,
    >> reproduce, modify, translate, display, perform, transmit and
    >> distribute any
    >> material you post to a news group in any present or future medium and for
    >> any purpose, including commercial purposes.
    >> END QUOTE
    >> So there we have it. CadSoft is free to use any material posted to a
    >> newsgroup as they wish.
    >> Regards
    >> Warren
    Hi Warren,
    Then it sounds like you're better off posting the ULP to the Online Repo
    then to the newsgroup. The Upload rules seem a lot less intrusive then
    the newsgroup guidelines.
    Funny how things work.
    Best Regards,
    Jorge Garcia
    Hi Christian.
    I would like to thank you for your ULP. It really saved me hours of work.
    Michael Kyriakakis
    "Jorge Garcia" <jorge@cadsoftusa.com> a écrit dans le message de news:
    jijbvh$cu7$2@cheetah.cadsoft.de...
    On 2/28/2012 2:59 AM, Christian Bohrer wrote:
    >> OK! No problem.
    >> You have my permission to download my negasilk ulp in the ULP section of the CadSoft site.
    >> Christian Bohrer
    Thanks Christian,
    I'm sorry if I stepped on your toes. I made sure to give you credit on the upload, thanks of
    writing the ULP.
    I hope the clarification will ease the concerns of other users and motivate them to post their
    ULPs on the site so that other users may benefit from them.
    Thanks again.
    Best Regards,
    Jorge Garcia
    Hi Jorge,
    Maybe I missed something but it seems there are two sites to post ULPs
    The old:
    http://cheetah.cadsoftusa.com/cgi-bin/download.pl?page=/home/cadsoft/html_public/download.htm.en&dir=eagle/userfiles/ulp
    And the new: http://www.cadsoftusa.com/cadsoft-downloads/
    If this is the case, there are 3 programs on the old site that have not been transferred to the new
    site:
    importexport.zip
    pcb-service.ulp
    gencad_131.ulp
    Best Regards,
    Christian Bohrer
    Hi Jorge
    QUOTE
    reproduce, modify, translate, display, perform, transmit and distribute any
    END QUOTE
    Regards
    Warren
    Hi Warren,
    Best Regards,
    Jorge Garcia
    Jorge Garcia wrote:
    On 2/27/2012 5:24 PM, Warren Brayshaw wrote:
    >> Correct me if I'm wrong. The terms of use of the CadSoft site are,
    >> if you upload something there the IP rights are transferred/gifted
    >> to CadSoft. There are no such terms for the Newsgroup forum and some
    >> authors elect to post content there but purposly avoid uploading to
    >> the website to prevent gifting the IP rights to CadSoft.
    >> It may pay to check out your action.
    >> Warren
    Hi Warren,
    There is no such condition on the site. Here's the upload statement:
    "You can use this form to upload a file to the CadSoft Download
    directory and make it available to other EAGLE users.
    By uploading a file you document that this file may be freely
    downloaded, used and modified by anybody who wishes to do so, without
    any limitations whatsoever – unless your upload contains a statement
    about a certain license that applies to your files (like, e.g., the
    GNU Public License).
    After you have uploaded your file, an automated email will be sent to
    you at the given email address. You need to reply to that message to
    confirm your email address before your file will be reviewed.
    Note that your email address will be listed on the download page, so
    that others can contact you in case of problems or questions.
    CadSoft reserves the right to decide whether or not to make any
    particular upload available for public download."
    We basically consider the ULPs as open source software, so no one
    really has ownership of them. Thanks for the concern, though it's
    nice to know someone's got your back. I made sure to give Christian
    credit for the ULP when I uploaded it. I figure sinced it was already
    in the public domain it would be OK to upload it to the site, kind of
    like a mirror.
    Thanks for the concern, and for making me look into this. At the very
    least it's taught me to be more careful.
    Best Regards,
    Jorge Garcia
    Hi Jorge
    QUOTE
    END QUOTE
    Regards
    Warren
    news.cadsoft.de
    OK! No problem.
    Christian Bohrer
    Thanks Christian,
    the upload, thanks of writing the ULP.
    motivate them to post their ULPs on the site so that other users may
    benefit from them.
    Thanks again.
    Best Regards,
    Jorge Garcia
    Correct me if I'm wrong. The terms of use of the CadSoft site are, if you
    upload something there the IP rights are transferred/gifted to CadSoft.
    There are no such terms for the Newsgroup forum and some authors elect to
    post content there but purposly avoid uploading to the website to prevent
    Warren
    Hi Warren,
    about a certain license that applies to your files (like, e.g., the GNU
    Public License).
    We basically consider the ULPs as open source software, so no one really
    has ownership of them. Thanks for the concern, though it's nice to know
    someone's got your back. I made sure to give Christian credit for the
    ULP when I uploaded it. I figure sinced it was already in the public
    domain it would be OK to upload it to the site, kind of like a mirror.
    Best Regards,
    Jorge Garcia
    "Warren Brayshaw" <warrenbrayshaw@paradise.net.nz> a écrit dans le message de news:
    jigvo5$lsd$1@cheetah.cadsoft.de...
    Jorge Garcia wrote:
    >> On 2/25/2012 3:55 PM, Warren Brayshaw wrote:
    >>> There is a ULP called negasilk.ulp by Christian Bohrer
    >>> It exists as an attachment to a posting in the eagle.support.eng
    >>> forum The easiest way to locate it is to use the eagle central portal
    >>> http://www.eaglecentral.ca/forums/ and search for negasilk
    >>> It's in the topic "silkscreen inverse text"
    >>> Warren
    >> The negasilk ULP has also been uploaded to the online repository at
    >> www.cadsoftusa.com-> Downloads-> User Language Programs. It's been
    >> submitted should show up on the list in a day or two.
    >> Best Regards,
    >> Jorge Garcia
    >> Cadsoft Support
    Jorge
    Did you get permission from the author to upload it to the CadSoft site?
    Warren
    OK! No problem.
    Christian Bohrer
