EAGLE User Support (English) Using the export image with a path with filenames?
  • Views 599 views
  • eagle
  • ulp
  • pcb
  • bug
Hi, so im tired of exporting the PCB for home etching, by hiding layers, exporting, and showing them again, so i tried to make this script to do that for me. However, it has to export to a path in my dropbox, and my users folder, has a space in it, so i thought, okay, ill just put the path in "", but it just ignores those, and gives me the error: Invalid value [second half of user]/documents/dropbox need DPI, is this a bug to be fixed, and/or are there a workaround?
    In the very last non-Cadsoft-person reply to the "Ask Richard" thread, I had verified that single quotes did indeed work under Windows (and double quotes didn't).
    the error: Invalid value /documents/dropbox need
    Use single quotes. that often works.
    news.cadsoft.de
