EAGLE User Support (English) cross the board change in via size
  • Subscribers 189 subscribers
  • Views 263 views
rickford66
rickford66 over 14 years ago
I have a number of via's on a board that I would like to change the drill size of.  I can manually do it to each by changing the drill size in the properties, but this will take a long time, and I'm sure to miss some.  Is there a command that will change the size of all the via holes at once?  Thanks.
  • rickford66
    rickford66 over 14 years ago in reply to e14 Contributor
    That worked perfectly.  Thanks.
    Deselect all the layers except vias ("disp none via"). Then, group
    (select) all the vias and type "change drill 0.02" (assuming you want
    the drill set to 0.02"). Then, right-click to apply the change to all
    the selected vias.
    Andrew.
