EAGLE User Support (English) Frame a PCB?
  • Subscribers 189 subscribers
  • Views 772 views
Frame a PCB?
rickford66
rickford66 over 14 years ago
Using a past program, I was always able to frame my PCB's just like Eagle allows on the schematics.  There were, of course, different layers.  On the drill drawing, I always put the board specs, such as material, finish, size, thickness, drill symbol chart, etc.  Is there a similar way to do this in Eagle?  Thanks.
    e14 Contributor over 14 years ago in reply to rickford66
    On 07.03.2012 19:04, rickford66 wrote:
    I figured out how to put the frame on the PCB, however, in the schematic, I created a
    part that incorporated both the frame and the document field.  Is there something
    similar for the PCB, or do I have to copy over the document field into the frame itself
    > and save it as part of the frame?
    There are already frames for the board editor in frames.lbr. If you
    want to have a frame of your own plus doc field you should put this
    into one common package.
    You could also have the deocfield as a separate package definition
    in the lbr. Whatever you prefer...
    Richard Hammerl
  • rickford66
    I figured out how to put the frame on the PCB, however, in the schematic, I created a part that incorporated both the frame and the document field.  Is there something similar for the PCB, or do I have to copy over the document field into the frame itself and save it as part of the frame?
