EAGLE User Support (English) Eagle lib creation - LQFP48 Pin Numbering
  • Views 821 views
I have created a part in a new library and when I opt for the labeling for
the pin & pad, I get P$1, P$2, etc for the pin - why not just 1, 2, 3, etc?
Is there some option I have on or off that I need to switch? I have seen
other parts in different libraries that have the same setup, but just show
the 1, 2, 3 and not P$1.
Please assist,
Bob
    Thanks you sir, that was it image
    Olin wrote on Tue, 20 March 2012 12:11
    Oops, I should have said "package" instead of "symbol".  When you make
    the package, you need to give each pad a name that will make sense when
    you go to make the connection between the symbol and package in the
    device editor.  For IC packages, these would usually be pin numbers
    starting at 1.  When you make the symbol, you give each pin a name that
    gives you a hint of its function.  Usually it's best to use whatever name
    the datasheet uses so people can clearly relate pins in your schematic to
    things described in the datasheet.  In the device editor, you use the
    connect dialog to define the binding between the logical pin names from
    the symbol and the physical pad names from the device.  Your problem is
    you forgot to set the pad names in the package so they are still the P$xx
    defaults.
    Oops, I should have said "package" instead of "symbol".  When you make the
    package, you need to give each pad a name that will make sense when you go
    to make the connection between the symbol and package in the device editor.
    For IC packages, these would usually be pin numbers starting at 1.  When
    you make the symbol, you give each pin a name that gives you a hint of its
    function.  Usually it's best to use whatever name the datasheet uses so
    people can clearly relate pins in your schematic to things described in the
    datasheet.  In the device editor, you use the connect dialog to define the
    binding between the logical pin names from the symbol and the physical pad
    names from the device.  Your problem is you forgot to set the pad names in
    the package so they are still the P$xx defaults.
    like this or something else, as I have it set to show pin and pad as I need
    that for different setups of the stm32 chip:
    bob4432 wrote on Mon, 19 March 2012 22:25
    You forgot to give the pins explicit names in the symbol.
