EAGLE User Support (English) Default VIA settings
  • Views 712 views
  • diameter
  • drill
  • size
  • default
  • drillsize
  • setup
  • via
Halo,
how / where do you setup the default VIA settings (drill size, diameter)?
Best regards, Oliver Schumann.
ISLE GmbH, Ilmenau.
    On 22.03.2012 16:01, Oliver Schumann wrote:
    Halo,
    ISLE GmbH, Ilmenau.
    You could do this in the eagle.scr in the BRD: section, for example:
    CHANGE DRILL 0.6mm;
    CHANGE DIAMETER  2.0mm;
    CHANGE SHAPE ROUND;
    Richard Hammerl
