EAGLE User Support (English) Auto Route (RipUp) Question.
  • Views 515 views
  • board
  • eagle
  • components
  • ripup
  • autorouter
  • route
  • schematic
  • auto
  • autoroute
  • layers
Hello everyone,
I'm rather new to the eagle program, I've made some schemes, but not THAT many yet.
I now am trying to make a "USB tester" (http://www.waitingforfriday.com/index.php/PIC_USB_Development_Board)
I've made the scheme but now I'm trying to get the board working. I'd like to keep everything on one layar, but when I auto route he cant seem to rip up every wire.
I've tried relocating several components for over 50times, yet, no succes.
Now I was wondering if there is any solution to this, for example is there a way for me to insert a "bridge" so the wires dont 'cross' eachother any more?
Any insight is welcome!
Thanks in advance.
Greetings,
Fedra
    Am 25.03.2012 15:24, schrieb Dimi N:
    Hello everyone,
    Thanks in advance.
    Greetings,
    Fedra
    The Autorouter (AR) will not touch nets layed by yourself.
    If you want a single sided board you could
    1. consider the tracks the AR places on the top layer as wire jumpers
    2. In the AR setup set the top layer to N/A so the AR will not use it.
    When AR is finished you route the remaining airwires manually on top
    layer, still considering them as wire jumpers which means they have to
    be staight, vertically and horizotally image
    Joern Paschedag
