EAGLE User Support (English) 6.2 Mac Add not Updating Library Change
  • Subscribers 187 subscribers
  • Views 244 views
jtowich
jtowich over 14 years ago
Mac v 6.2: If you modify a part in a library, then go to the ADD window in the schematic mode to add the part, the modification is not there. If the unmodified part is added to the schematic and the Update Library menu item is selected, the part is updated properly in the schematic, but the ADD window part is still the older version.
    autodeskguest over 14 years ago
    Are you sure that you saved the library file before using it and could
    it be the case that you modified a library with the same name, but maybe
    from a previous version of EAGLE? So the ADD dialog a does not show the
    library you modified?
    Richard Hammerl
