To have PCB text in Gerber files look as it does in the layout tool, you have to use vector fonts. Because of this I like to keep the "Always use Vector Fonts" checked in the options. The problem with this is when generating PDF's of your schematics, the text is not searchable, so I have to go into my settings and change back to non vector fonts just to generate the PDF. If you could make an extra option have one setting for PCB layout and a different setting for schematic that would be great.
It would also be nice if net labels in the PDF were links, so when you click on one it would go to the next label of the same name. I have seen several schematics like this in the past and they make looking through the document so much better.
John Vickers
