EAGLE User Support (English) Printing Holes in Pads
  • Views 985 views
Hi Folks,
I am new to Eagle and finding my feet.
I have a situation where with my HP1320 laserjet when i print my PCB layer
including pads, vias, holes, drills etc it does not print the holes in the
pads.
I have got the display mode set to real, and i have also experimented using
the drill-aid script.
Still the HP does not print the holes in the pads.
Using exactly the same project and the same settings i print my PCB layer
from my office PC to a Lexmark C532 laser.
Using the Lexmark the layout prints great with holes in the pads.
Has anyone had any experience with this problem or does anyone know of a
solution?
Many thanks
Ade.
  • bastl
    bastl over 6 years ago in reply to bastl
    O.K. I found a solution. I turned of the Bottom layer and printed only the vias.
  • bastl
    bastl over 6 years ago in reply to e14 Contributor
    Not for me!
    I have Eagle-9.5.2 on win10.
    The wires are laying over the via holes when connected.
    How else can I get the drill holes printed?
    It is very important. I have to control everything before manufacturing. So is there any possibility to get via holes on paper (foil)?
    That would fasten the PCB development enormous. Else I have to let manufacture the PCB and that 10 or 20 times until all
    holes are fitting.
    You have to set white background  - then it works.
    I forgot to mention.
    Windows 7 Pro/ultimate OS.
