EAGLE User Support (English) Putting dimensions on a layer
  • Views 870 views
To create correct documentation I would like to place  dimensions on a
layer.
Is there a script that can do that?
Regards
Harry
    "Harry H. Arends" <info@oldtimetech.nl> a écrit dans le message de news:
    jses3r$9bg$1@cheetah.cadsoft.de...
    Hi Christian,
    Where do I find it?
    If you are talking about mechanical mesures to place in a drawing layer,
    the eagle command corresponding is called "Dimension".
    You can see the explanations about this command in the EAGLE Help
    Simply enter the word: 'dimension' in the Find: field of the eagle help.
    jognfv$694$1@cheetah.cadsoft.de...
    >> layer.
    >> Regards
    >> Harry
    This feature is already implemented in V6
    M_]C_X `02D9)1@`!`0$`8 !@``#_X0`V17AI9@``24DJ``@````"``$#!0`!
    M````)@````,#`0`!`````,I+``````"@A@$`C[$``/_;`$,`" 8&!P8%" <'
    M!PD)" H,% T,"PL,&1(3#Q0=&A\>'1H<'" D+B<@(BPC'!PH-RDL,#$T-#0?
    M)SD].#(\+C,T,O_;`$,!"0D)# L,& T-&#(A'"$R,C(R,C(R,C(R,C(R,C(R
    M,C(R,C(R,C(R,C(R,C(R,C(R,C(R,C(R,C(R,C(R,C(R,O_ `!$(`+@!T@,!
    M(@`"$0$#$0'_Q `?```!!0$!`0$!`0```````````0(#! 4&!P@)"@O_Q "U
    M$ `"`0,#`@0#!04$! ```7T!`@,`!image
    M%5+1\"0S8G""0H6%Q@9&B4F)R@IC0U-C<X.3I#1$5&1TA)2E-455976%E:
    M8V1E9F=H:6IS='5V=WAY>H.$A8:'B(FDI.4E9:7F)F:HJ.DI::GJFJLK.T
    MM;:WNFZPL/$Q<;'R,G*TM/4U=;7V-G:X>CY.7FYCIZO'R\_3U]O?X?K_
    MQ `?`0`#`0$!`0$!`0$!`````````0(#! 4&!P@)"@O_Q "U$0`"`0($! ,$
    M!P4$! `!`G<``0(#$00%(3$&$D%1!V%Q$R(R@0@40I&AL<$)(S-2\!5B<M$*
    M%B0TX27Q%Q@9&B8G*"DJ-38W.#DZ0T1%1D=(24I35%565UA96F-D969G:&EJ
    M<W1U=G=X>7J"@X2%AH>(B8J2DY25EI>8F9JBHZ2EIJ>HJ:JRL[2UMK>XN;K"
    MP\3%QL?(R<K2T]35UM?8V=KBX3EYN?HZ>KR\_3U]O?X?K_V@`,`P$``A$#
    M$0`_`/1%\*R(BJFHE=HQ_J>OZU(/#MRO34O_`"!_]E705R_AVX\3:MI&E:K<
    M:EI"PW<$-S)!'IL@8*ZABH<SD9P<9V^.U<OLXCY46O$?N?@D/_'_`-E1
    M_P`(_<_]!$?]^/\`[*H?[9NY9M%VSPE;C6JTF\E#M:.-K:IWC(8&),D<$J
    M<':>='7M-GU(V$<SF;<T:L87$3NN=R)1L=QALJI)&ULCY3@]G'L%D4_P#A
    M'[G_`*"(_P"_'_V5'_"/W/\`T$1_WX_^RK>HI>SCV#E1@_\`"/W/_01'_?C_
    M`.RH_P"$?N?@B/_'_V54M$G\5ZQH.G:I_:NBP_;+6*X\O^RI6V;U#8S]H&
    M<9QG`K5O/$>G6-V]LXO9I8\>82PGN A(R%8QHP5L$':3G!!Q@BG[./8(K_
    M`/"/W/\`T$1_WX_RH_X1Y_Z"(_[\?_`&58</B^MO \VJSR0W%U;';74-
    MH@=G::1),LX0`;"R#[N-N')VC!KK]/U&#4[=IK=+I$5MA%S:RP-G`/"R*I(Y
    MZXQ^5'LX]@LCDM76YTN[6#[0)=R!]VS;W(]3Z50_M&Y_OC\JU/%O_(5B_P"N
    M`_\`0FJA%%9QZ='<7$4\CR2N@$<H0 *$/=3G[WZ5@UJR'N1?VC<_WQ^5']HW
    M/]\?E4O]GFZ"/IZR3!RP,9 WH0N[''7C.#P3M;CBHO[/G\_R1Y+-MWEEG0HH
    MSCE@<#GCD]QZBE9@']HW/]\?E1_:-S_?'Y4V:QN($:21!L!4;U<,ISG&"#@_
    M=;IW!%)]DG\[RMGS^7YN,C[NS?G_`+YYI68A_P#:-S_?'Y5U/_"/W/\`T$1_
    MWX_RKC*]1K2G%.]RHJY@_\`"/W/_01'_?C_`.RH_P"$?N?@B/'V5+:
    M(-GA"?6M0C_>6,4_VQ;=>#) 667RP3]TM&VW)!QC.*DL]3N8;B>'5[G3XWM-
    M.M[FZ,6]5C=C)&W/QY?[OY><C#;NU:^SCVLB+_`(1^Y_Z"(_[\?_94?\(_
    M<_\`01'_`'X_^RJQ#XDTN:%Y?-FBV2Q1-'<6LL,@:5PD9V.H;:S'`;&,AN?E
    M.Z7EN]_-8K)FYAB2:1,'A'A3GIR8W_`"]Q1[./8.5&1_PC]S_T$1_WX_\`
    MLJ/$?N?@B/'`-E6O97EOJ-A;7UI)YEM<Q+-$"-R, 0<'D<$=:GI>SC
    MV#E1@_\`"/W/_01'_?C_`.RH_P"$?N?^@B/^_'_V50^([KQ!IRBZL;[3%MI+
    MJVMTAGL)'=?-E2(DN)E!P78VCICWJ?^V6TC_1M9NOMMXW[P#3-G;9&>%WH
    MAE*Y(;!)`." /E-/V<>P60G_``C]S_T$1_WX_P#LJ/\`A'[G_H(C_OQ_]E5R
    M[U[3;.WMIFF>=+I?,@%G"]RTB8!WJL08E/F7YL8^9>>1FI=:SYUQX>DL)\VU
    M[?O#,"F"56WG8HP895@\8R.""I![BCV<>P60G_"/W/\`T$1_WX_RH_X1Y_
    MZ"(_[\?_`&56+/Q)I=_=I;V\LQ:7/DR26LL<4^!G]W(RA),J"PVDY4%AD FM
    M:E[./8.5&#_PC]S_`-!$?]/_LJ/$?N?@B/_'_P!E5SQ%J$ND^&=5U*W5
    M&FM.:>-9 2I9$ '!!QD>M:5'LX]@Y48/\`PC]S_P!!$?\`?C_[*C_A'[G_
    M`"(_P"_'_V596G>,1]OB&H7/GK<:/8WD<5A:2S;GD,WF2(BJ9-GRQC+#C@
    MX+<[4WBO1H$M&>Z=GNUD:"*.WD>63RR%D41JI;>I;YDQN&&R!M;#]G'L%D1?
    M\(_<_P#01'_?C_[*C_A'[G_H(C_OQ_\`958N?$>G6GDB07KR2Q,(H">61$
    M;[I=$0M'G! W`9*L/X3AD7BO1KB^^QVMT]W-NC5OLMO),J;U5T9F12JHRN"'
    M)"GYN?E;![./8+(B_P"$?N?@B/_'_V5'_"/W/_`$$1_P!^/_LJT%UFP?2K
    M35%GS9W?D^3)L;Y_.95CXQD9+J.1QGG%7J7LX]@Y48/_``C]S_T$1_WX_P#L
    MJ/\`A'[G_H(C_OQ_]E6]7-V=YX@UVT34=/N-,L&;6RSVTER\T1/R2DB2/9
    MN7!V8)'<Y) ?LX]@LB;_`(1Y_Z"(_[\?_94?\(_<_\`01'_`'X_RJ&#QC9
    MP_Z+JZ_9-5666)K*W$ETS%-C?N]J9?,5 P:,*'5MC$KN R2F,[E!/9Q[!9$W_"/W/_`$$1_P!/_LJ
    M/^$?N?\`H(C_`\?_95::]!<WEX[S)!96]G%<G[3#+;RQ O,&:02!0J8BX[
    M\,3P5)$\5:2UO=32275NEK ]S(+JRF@;RD&795= 7"\9V@XRN>HR>SCV"R(O
    M$?N?@B/'P!E1_PC]S_T$1_WX_\`LJL6?B32[[2WMY9BTN?)DDM98XI
    M\#/[N1E"294%AM)RH#(!-%GXDTN_NTM[>68MGR9)+66.*?`S^[D90DF5!8
    M;2<J"PR 31[./8+(K_\`"/W/_01'_?C_`.RH_P"$?N?@B/_'_V5;U07OVO
    M[!<_8/)V>4WD>?GR_,P=N['.W.,XYQ2]G'L'*C(_P"$?N?@B/^_'_V5'_"
    M/W/_`$$1_P!^/_LJI7GC+:OAZ>SMMUMJL4=P?.X=8WEMX@.,@,#<JQ/(_=E?
    MXMRVKG7;E;S45B:UBM[2\LK+=.KEFED>,R?=SP4FB"'C#[MWRC-/V<>P60__
    M`(1Y_Z"(_[\?_94?\(_<_\`01'_`'X_RI3XQT022H+F9U@E>&>:.TF:*!T
    M8JXDD"[(\8).XC"X;[I!-O4-=L=,N%MY_M4DQ7>8[6SEN&522 6$:L5!(."<
    M9VMC.#@]G'L%D4_$?N?@B/'`-E1_P`(_<_]!$?]/\`[JND>H&T5+
    MN_DNI)9[R\2&*.RE>;RH[AT7,2(7`50BDE1@D \GG:M=9L+R2VC@GW27,4DL
    M:E&!VQLJR!@1\K*SJI5L$'(QP<'LX]@LC/\`$?N?@B/^_'_P!E1_PC]S_T
    M$1_WX_\`LJT/[9L/L7VOS_W'VK[)OV-_K?.\G;C&?]9\N>G?..:O4O9Q[!RH
    MP?\`A'[G_H(C_OQ_]E1_PC]S_P!!$?\`?C_[MZLWP[J$NK>&=U*X5%FN[.
    M&>18P0H9T#$#))QDM'LX]@Y44_$?N?@B/_'_`-E17CWB+XX^)M)\3:KI
    MMO8Z0T-I>301M)#(6*HY4$XD`S@>E%7[%=@LCW^N0\(>$-$MO#.@W%QX=T^+
    M4XK.W>222R19DF"*222NX.&[]<UU7F3_`//G+_W\B_\`BZ/,G_Y\Y?\`OY%_
    M\73U&<C965VG]A[K68>7XBU&:3,9^2-OMNUSZ=Z8/0[AZBLW2=GM['2-!U
    M'4?$<T]DUJK6L=C%]E)A9&5A/Y('EC8&YDWE1M(W_7H'F3_`//G_W\B_\`
    MBZ/,G_Y\Y?\`OY%_\73U`EHJS)_?.7_OY%_P#%T>9/_P`<O\`W\B_^I6
    M8SSCP[8#[?PSI4.I>$'-_'9PI<F3PQ.[&4(`V6\DY.<\Y.:Z33[X'XKC3;
    MFQU":Y>\N9X?LMI)',LTSR(!(!L0_/M/F,N""3\N&/19/_`,<O_?R_XN
    MCS)_^?.7_OY%_P#%TQ'GFGZJ4WA4%;*9;F?P?96<:2LS,([D&/+8`8%E
    MR#TR,XKO=/U&#4[=IK=I$5MA%S:RP-G`/"R*I(YZXQ^53>9/_SYR_\`?R_
    M`.H\R?_`)\Y?D7Q=)W8'(?^0K%_P!<!_Z$U4XX&NM'@2.2`.EQ*662
    M=$(!6/!8CT/Y5LZUI&H:MJ0:VMCF.%0P:1,\EL="1ZU0_X1#6O?5?^_J_X
    MU@X2N]"&M2.TDALXY7SXW>1)6E93\JD0NJJ#W.6;.,@_@]:K:>BE)6C,!N
    ME*6+AD";>=Q?Y2?NC!]2<<9%W_`(1#6O\`GU7_`+K_C1_PB&M?\J_P#?
    MU?\`&ER3["L2O/;O+#!=30E'LBDS6VT!"LK2;0``NX[0OH2V>>]:?4EN].N9
    MY<"Z<F$HO V-)YNX<YX8,#[,OXR?\(AK7_/JO_?U?\:/$0UK_GU7_OZO-/
    MEGV#4PZ]1KBO$0UK_GU7_OZO-=GB[_`.@?/_WW'_\`%55.$E>Z*B<E?:9>
    MOXH>SCMG;3^\MM2GN.Z/"O(!Z ;H,8(R1))C."4C\0:1?ZCJVK_9$F1OLN
    MER12H%!9H;J:5ECC87V@8#<99=V`<UV.O_`*!\_P#WW'_\51B[_P"@?/\`
    M]]Q__%5M9E'#II>(_M\)U3Q!<22Z9<V(GU+3EMXX!-L!POE1,['8#QD`<E
    M<C-&]T/5M2T'UWM/(U+7/,M[ZU=OLMO=K%#DM!QK% S!L#Y9NF5V^C8N
    M_P#H'S_]]Q__`!5&+O\`Z!\__?<?_P`51KV =13<7?\`T#Y_^^X__BJ,7?\`
    MT#Y_^X__BJ5F!D>*();C28$AB>1QJ-BY5%)(5;J)F/'8 $D]@":J)=#P_J
    MKO>V]Z\6H72W,$EI9RW(P((HBK"-6*L#'GD`$,,$D,%Z+%W_`- ^?_ON/_XJ
    MC%W_`- ^?_ON/_XJG9]@.+T>WN?#-_=:CJ5I=>3J"L0MK ]R\#&ZN9PDBQ!C
    MG;<,KN7,-WW=SXK*[EUNRU/[,L%WKK7:J\9#QQ#3GA#2#^#(" >1O4$!
    MLJ.L2>60$K9RX#%3EXQR"0?XO4&G>9/_`,<O_?R+_XNEJ!R.AO<6FHZ?IF
    MOK7V.,,]CJ%D(XK.%8VVB.81KYC*XC08DDRI8_-]\=G47F3_P#/G_W\B_^
    M+H\R?_GSE_[^1?\`Q= &7XO@EN?!6O6]O$\LTNG7"1QQJ69V,; ``<DD]J?9
    M(K*_NTMH8-361\X,EW,*<#/O&%'3N?:M'S)_^?.7_`1?_%T>9/_`,<
    MO_?R+_XN@#@_#%RWA_[!_:-CJ:;_``[ID/[K3IYMLD?G[T;8C;6&Y<@X/-7M
    M)LKL.FU=K6:.UOHKN6/S(RK(I6QC4.#]QF\EV"GG'4`A@.N\R?_`)\Y?_D
    M7_Q='F3_`//GW\B\`BZ>H'*ZK)YVLWD.J0ZZP1E73H=-S&DJ%%)9I(B%
    M#F0NO[QP%"<"6:/X:V5W8:!+'>6LUO(?LF%FC*'BQM5/!]&5E/NI':NN\R
    M?_GSE_[^1?\`Q='F3_\`/G+_`-_(O_BZ6H'Z=I\K>'L0R-8:5>3:@DBDEO
    M.N%8B-CC&5\ZX8KP0KVYR<MGKZIV]N6:ZFAT^59J433'SHSN<(J \OQ\J*
    M./3ZU/YD_P#SYR_]_(O_`(N@"6N4T75!X=T6ST;4K#4TEL(A:QR06$MREQ''
    M\B2@PJX7<%SL8AES@@C!/3>9/_SYR_\`?R_`.H\R?_`)\Y?^_D7_Q=%@.#
    MAN'TGQI!JNJ65[;R:E%?2_9(K=KJ2$ V42[O)#]5A#D]`7VY.,FWJ5O<ZI)?
    M:U;VET+4MI@1)('29UMKMII7$1&_&UR "-S%#A2"I;JGMP]_#?-I\IN88GAC
    M?SH$<H6&-.3&GY>YJ?S)_?.7_`+1?_%TP..O;>YUK4]0O;&TNC$8-+FC
    M$\#P-;>\FD=`) N'PHP&P/F4D@'-5_&4DGBK09H]LM08VD%U,_GV,T!<M:
    M3QB(H9W2@X4$`<D$J&[GS)_?.7_`+1?_%T>9/_`,^<O_?R_XNC4#
    M\402W&DP)#$\CC4;%RJ*20JW43,>.P`))[ $UBZ&]Q::CIGZ:M?8XLPSV.
    MH60CBLX5C;:(YA&OF,KB-!B23*EC\WWQUWF3_P#/GW\B^H\R?_GSE_[^
    M1?\`Q=4"6BHO,G_`.?.7_OY%_\`%T>9/_SYR_\`?R_`.+HLQG!V'AS4KO3
    MM>L7@^S-:VK:9I#7'_'9)))#&PSA0C6GSCYMT'/S(#5N.UO;OPH+V:PNHK
    MW4-;MKV6&1/WJQ"\B\O>JDA2L$<>X=MI)YR:['S)_P#GSE_[^1?_`!='F3_\
    M<O_`'\B_P#BZ>HC\P2VDSI-$\;G4;YPKJ02K74K*>>Q!!![@@US7@V23
    MPKH,,>JV6H*;N"UF3R&:<H5M((F1UC4LCAHB<,`"&&"2&"]SYD__/G_P!_
    M(O\`XNCS)_\`GSE_[^1?_%TM0.&\-M<Z)<7FJZEINH0PW[3((X[5YY866]NY
    M`'2(,<,LRD,N5.T\C*[IZRU8P3Z[IMKF[DUANRMKF-QE7MELPTH'S(HW&4
    MC&0JX(4D[>U\R?\`Y\Y?^_D7_P`71YD__/GP!(O\`XNGJ!QUAX8ET?QI
    M5A:AVTF!1>K<299Q-%;"S\MB`% :-XW!ZYCDXP1M[:HO,G_Y\Y?^_D7_`,71
    MYD__`#YR_P#?R_XNEJ!7&>%_!/A_\`X1+1?M_AC3/MGV"#S_/L(_,\SRUW
    M;LKG=G.<\YKKO,G_`.?.7_OY%_\`%T>9/_SYR_\`?R_`.HU ^3_%'@GQ!_
    MPENM?8/#&I_8_M\_D>182>7Y?F-MVX7&W&,8XQ17UAYD_P#SYR_]_(O_`(NB
    MKYWV%8<6?S8U6/<ISN?<!LP...3QQ4=W<?9H5DW0C,L<>9I?+7YG"\'!;G
    M@?Q'`R,Y#G3==0-Y._;N.\O@)\I&<9^;/3OUS3;OS/)7RO.W>;'GR=F[;O&[
    M._C;C.>,[?FQ4#*$NL>7#+)YNF#9%=29>VJ/)<R=G"C/[P_\`,\8;K5^
    MWN/.FNH]T)\B41XCEW,/D5OG&!M;YNG/&TYYP*$OVWR9=O\`:>[RKK;L^S;M
    MV\>7C/&['^KSQC_6?-3-'\1:1JU]>6]AK%K>RV]8XKF&3";4!B,EMFX]7Y
    MW$_P[: UZQ-M=KG@0$C\F_PJ6)8K"^6"#3[ J8@Y+VX)R21V(]*DO/]1>?
    M]>_]&JMXD_Y"Z_\`7!?_`$)JX<?.4*+E%V=U^HXI.6I4_M$_] 3/ ;_P"O
    M6QH0MM3M[AY].LE:*;RQLA !&U6SSG]EI
    M4K\LW=6G%)&C-9Z5;('GMK)"ZH&=%4%F8*HY[EB !W) JOJ3^'M&MUN-4;
    M2[&!G"+)=&.)2V"<`M@9P"<>QK-\=K$=%L9'LI[J2#5;*>,06;W#Q[)T9W 1
    M6XC$G/OCJP!N>-()KKP+XAM[>2:>73E(XXU,[&)@``.22>,5]#RKL9$N
    MD7&FW=S-<Z3:36<L,926T96C<AY`<%>#R,?A4'B/QIX=\)&=<U2*S,H+(A
    M5G=@"!DH)ZGT_E3]_M'_A)=?\`MO\`Q[[X/L/W?]3Y0STY_P!9YOWN?PQ5
    M+0?!D.D(]8U]NO[1U_N"T4\L0!M8/X84))P!DY(QNXR.:6@%KPYXT\.^
    M+5D.AZI%>&(!G0*R.H)(R58`]1Z?SK>KS;XD6UMIWB?P7K=GMM]6FUR"QDDB
    MPKSV\G#J.6 VJ.>F[WKTF@"O]OL_P"T?[.UP?;O*\_[-Y@\SR\[=^WKMSQ
    MGIFK%>3_`/"2V']G?\)+]GU7SO[;_M/?_9-U]GRXR;N\O&W[']^]]_GI
    M\E=A8?VMJGB76]^MSV]CIVH1Q0VL$$7SK]G@D99'96)4ESC;M89;YC\NT ZB
    MBN;\-R:GJ]EIOB&35)!!J%NEPVFF&,Q1(Z;E5& #[QE<LS,&^?"+N79TE !1
    M110`4444`%%%% !1110!S]I/%UVD<J.\-UDBJP)1MQ;!]#AE./0@]ZLU6M
    M((HFNWCB1'FNI7D95 +MNY/J<HSZ #M6!XS\5R^';>TL]-L7U#7=29HM/M
    M%!VLP W.YX 1003R/J!EEPZE&MJ'B+1-)N%M]2UC3[9EWK'<W1L5R1D!B#
    MC(//M5NSO;34;1+NQNH;JVDSLF@D#HV#@X8<'D$?A7(>'?ASI]K;S7GB:*UU
    M[7;UA+>7=W"LJAL<)&&&%0#@8 SCH `J]?9V5IIUHEI8VL-K;1YV0P1A$7)R
    M<.!R2?QH=@FH>(M$TFX6WU+6-/LIF7>L=S<I&Q7)&0&(.,@\^U5/\`A-O"
    MG_0SZ+_X'Q?_`!5<OJ&EZ?JWQR6WU*PM;V%?#>]8[F%9%#?:2,@,",X)Y]ZZ
    MC_A"?"G_`$+&B_\`@!%_\31H!LP3Q7-O'<6\J2PRJ'CDC8,KJ1D$$<$$=ZDJ
    M.""VMX[>WB2&)0D<<:A510, `#@ #M7$ZS;ZUXJ\:3Z ZWMEX5MK53?2+$
    M(_[0D8@4LF<[-O#%,'AU/WE- '0S+_``S;7$EO<>(M(BFB8I)')>QJR,#@
    M@@MD$'M6S7/0>!/"-O;QPIX9T@I&H13)9QNQ`&.68$D^Y))KH:-!A4%S>VEE
    MY/VNZA@\^588O-D"9(W1%SU8X. .:Y.](7V*_N;3_A#_%L_D2M'YT&F;HY
    M-I(W*V[E3C(/I4%EX<U?Q+XETWQ-XI@AL5TWS/L.C)LG\MR /-DEZ,V1D!1\
    MNU#G(;);N(S'9O!?7HR1<ECI]LTTS1YP7P. ,]R1T.,U
    MT%>:)$(6DZ1JT-JUJTHG@N%EASNV%"W7=SD9/L>*$@-_1O'/
    M]L:K!8?\(MXGL?-W?Z1?:?Y4*84GYFW'&<8'N175US_@?6[SQ)X+TS5[^W$%
    MU<QDN@! .&*A@#V8`,/KWK:O+N"PLI[RY?R[>WC:65\$[549)P.3P.U/E;=D
    MM0)J@BNXYYF2(,ZK]Z0#Y0?3/<_2N!UGX@Z%JRZ?'I&JR2".^B:[5(I$S!\P
    M8'(&0?2O1%544*BA5 P`!@"IJ0J4ZKI5%RM6NFK/77;H/FIM>[)-]5V]?46N
    M<U_Q6-!U*VM/[OPS1E_P#1EW.<9X5?XCQTR.HK6U;5K+0],FU'49_(M(=O
    MF2;&;&2%'"@GJ17$R>+]#U_QCX<N-,O3<1023Q2-Y3KAI$"J/F [TYTZJI>V
    MY7R)I-VTW6E]KDOD;Y95%#?7?9-I?-Z>5SJM`\0_V]]H_P")/J^G>3M_Y"-M
    MY/F9S]WDYQCGZBM8,3.ZYX"J1^9_PI]1K_Q\O_N+_-JNK*$IMPC9=MQK;4@;
    M5-/5[Q&O[4/9*'NU,RYMU(W OS\H(!.3C@9HMM4T]=4M;UG=EWJL4RL2N$
    M;(P>F)(SGT=3W%<I_P`(Q+J'B76;E@\%O/J*)=J<JMW;"VMV`Z8<>9&4P?EV
    M23KU:L+PIIE_#=Z%-J]MJ\=O:0);0A//7RY&MK JK*G/E[XY]VX>6&!W<U%@
    M/4ZBN!N1%RP#2QJ=K$'!< \CVKS&QMO%V@$NIZNV1K1;X16RO
    M(Z,`OG?ZE!$5R6&W8#WD,*VK-"AU I'%9(IG=GA($KCY68DF3^222/I-
    M`]CH?[)M/2?_`,")/_BJ/[)M/2?_`,")/_BJX3QW]C_M'6_MOD?;O[$C_L#S
    M\>9]LS<9RYY\[/V?.SYL7_`->D5MR1[$ER;3TG_`/ B3_XJCR;3TG_
    M`/ B3_XJKM%')'L!2_LFT])__ B3_P"H_LFT])__ B3_P"J[11R1[ 4O[)
    MM/2?_P`")/\`XJBKM%')'L!SINM/:6.5KF M'G;^^Z9&#QGGCUI)KC3;A DT
    MUK(@97"NRD!E(93SW! (/8@&KBSW!DD#;U1<;7W_`'\YSQU&..OK5B$2S9_>
    ML,>YK*U]"C$:0W1D>/3F1UE1E(0AEE.Z0'V<\L.YY.:CL30-,N[ZZL4L;>
    M>_E\ZZDC9097QC)_4_4L>K$GHS#(.MPWZUC:AXETG2[CR+W5X8)",A9)54D?
    MB:?*QQBY.T5<9<W-M)#<A+JW)>'8H\U>O/O[U!J<NG:G="X>YO(6"!,12V^"
    M`2?XB?6D_P"$W\._]#!:_P#@0G_Q52VWB[1+RY2WM];@EE<X5$F5F/T`;)_"
    MLYTHS7)71;I5%K9E#[I>0?MVH<=O-M>:U-,U'3]+@DBB:>022&0F26'.<`
    M8X8<8 K96.1AD3M@C(.>M-F26) WG.><=32IX6G2?-"-F97OI<J_\))9_P!Q
    MOL7Q='_"26?\`<;_O[%_\75B'S)G*:XP,]34YMY /^/A_P#/XUNN9A8J
    M:;>QWHW4L0(411RRGG_W21WK4JA;(R:K<AG+'R8N3_O25?JUMJ(YL#K6
    MX\:-XEO[J>]EB0+8VTQS%9' #LB_WFP"3U_3&Y?VOV[3KFST3V_GQ/%YUN
    MR2/<"-R-V89R#V-6**8%?[!9_P!G?V=]D@P5Y'V;RQY?EXV[-O3;CC'3%4
    M]$T.'0X9TBNKNZ>=XWEFNI -/O(W@U
    M"^6QAS]GTX.H@A)!'RX4.5 81F*D;5&U-NQ14<T\-L@>>6.)"ZH&=@H+,P
    M51SW+$ #N2!0!)1110`4444`%%%%`!1110!SL=W;1-.DEQ$C">7*LX!'[QJ?
    M]OL_^?N#_OX*9'K.FVC303WS),)Y<HN3C]XQ[#TK2M+JSOA_HU\9,#)"R<CZ
    MCM6;IRW'<H?;[/\`YX/_@HWV?_/W!_P!_!6SY'_3:7_OJJ/FR?\]'_P"
    MC4N-AWGV^S_`.?N#_OX/M]G_S]P?\`?P5K?9I/?A_U_QHS2?\_#_`.?Q
    MI\C"YD_;[/\`YX/_@HWV?_/W!_P!_!6M]GD_Y'_S^-)Y,G_/=_U_QI<C
    M"YE?;[/_`)X/_@HWV?_/W!_W\%:OD2?\`/P_Z_P"-0++&]P8%OLRC$'_
    M`.O3Y&%RC]OL_P#G[@_[^"C[?9_\_<'_`'\%6_-D_P">C_\`?1JLU_*K$9;A
    MB/O_`.?_`-?%9N45N-)O8;]OL_\`G[@_[^"L2P[XAE26+1M CD1@R.EK""
    MI'((..#6C?>)?38W%Y<K#&.27EQ7-R?$]9F8:3I=_J04X+19"_F12]I"U[
    MC<6MSKOM]G_S]P?]_!1]OL_?N#_`+"N-_X63JJ',_A+58XQ]YQK8_M/3
    M/B'I>IR"$7#P7!./)F8JWZTE4@]G<E.^QM3RZ7<[//DLY=C;D\QE;:?49Z&I
    M?M]G_P`_<'_?P4O]HRDX`D/?[_:IX[B5XPQ=AGMN-.,X-V13@XZV*_VS_Y
    MX/\`OXBDETN6>.:22S>6+/ENS63/7![5G:AXO-CJDUC]GFW7O7-7'Q::"XDC73A*JG D2\.&'KR@IWB93J06DCN_M]G_P`_<'_?P4P7
    MMH)F?[7;X@?ZP=L_P"->8S_`!W1)UMX-(:>9CC OL/QV57O/CY<V,_DS>'
    M#OQGY=2)_P#:=6HW4DU='K/V^S_`.?N#_OX/M]G_S]P?\`?P5X]_PT1)_T
    M+C_^#$__`!NC_AHB3_H7'_\`!B?_`(W3Y&.Y[#]OL_\`G[@_[^"HYKVV9%\N
    MZMBRNC@-* #M8'&>?2J?A'Q-)XJ\+V>M>2]K]IW_`GS2^W:[][`S]W/3O7
    MEOC[XS>)?"WC;4-%L;?3I+:V\O8TZ2%SNC5CDAP.K'M2Y;Z SV;_`(2 ?]./
    M_@9_]C1_PD Z<?``,_QKYU_X:'\8?\>D?]IO_CE;A?%/XG^)&QIF@Z
    M;N<&0Q2J@^I,M:%26Q+:6Y[7_PD Z<?\`P,^QH_X2 ?]./\`X&?_`&->
    M>2:O\8TA\P:7X;<_W%E<M_Z-Q7%ZO\9OB-H,YAU/1-.MG_VX)L'WSYE/V=2U
    MQ71[O_PD`_Z<?_ S_P"QH_X2`?\`3C_X&?\`V-?.O_#0_C#_`)\](_[]3?\`
    MQRO2/A/\1M:\=_VO_:D=K#]C\GR_LJNN=.=S-<'IWJ'S+J4>A?\) /G'
    M_P`#/_L:G\V3_GH_P#WT:GF?<+%>),7%P_D[=VP>87SOP#P%SQCZ#.?:KU
    MF<%S]HQ)BXN'\G;NV#S"=`> N>,?09S[53\0W\VF>&M0O( I>(L`W0\'
    MK[4)V=RXQ<FHKJ5_%'B<V[)IFFHLVH3CY5)6->[N?[HQ/0=ZJ:/;6>EP2&
    M39=W<[;[BYF0%I&_H . HZ"N9T"RNKVUDOH9HY#,X$UW-(%\Z3'W5^G `' Q
    M6G::?JUXTB(D:R1.8W1Y`K!AR>.XYSGWJ.=MGK_5J5*/L^976_\`7D=+]NM/
    M^?:V_P"_2_X54U)--U2R>UGMXU5N5>$!'1AT96'((ZUSXM]2?5/[/58VF$?F
    M,5E!15]2>U1WHO;"[@MI@I-QQ$R/E7YQP:3FQQP]-27++7?]3=\/^(I["]&B
    MZQ(KRMG[-= 86X']&]1^-=?<,'@!4Y!((/X&O.-5T'4Y+*87,$<BQ?O&$,P,
    MD9'(8=P1P>*V_!.J76J>'6:[D$DD,[0^9C&_:3\WX_SJXS=N5G)BL/#E]M2:
    MMU2[7]?\#J;/_7'_=_J*EOKN.RLWGE95"C.&/4]A=16?\`KC_NUY1\3_%1
    M77/[-CFQ';-RCDESS_M8;'GLZ[X=7FJZ@NJW6L2A[F65&55.1&F#A1].?S
    MKURTLM0FELC519VKZJ\UU80VQE78$E7A)(G5Y))6AD*E=NYXBH+NLDJ_!R
    M\:]TS59&WY%PJ_..?NY_K6QH5AK'AN?6Q%I3WD-]JD]K?'&P5R/E R<G"-
    MC)&=\6=NY_*&VC2G&,D[_P"1E:%I&B7NO>'+NY&FZEJMKIAAN[K[,TLD]RH@
    M3B1D^8(F(D8@@31$<2KGTBN0N--U75O&7A[5;NP^R1:7]I#;)EE#F6/9G.
    M5(4%&YP20T? )<1]/?PW%QIUS#9W7V2ZDB=(;CRQ)Y3D$*^T\-@X.#UQ1%M[
    MBJ1C&W+_`)]3R_\`X2SPW_:/_"3_`/"0:5]N_MOR/)VQ9]CS]DV;LY\G/^
    MEXQMS_WW72/!KTGQ&UDZ=J6FVZ?V98G%QI[S';YES@969.=P<Y]&48&TEND_
    ML33O$>_L#[/_P`2S[)]B\C>WIV;-N[.[[O&<Y]ZSX-#U2VU&UOTU>"6Z:T
    MM[747GL\_:1$7.Z,*ZB)F,LF<[QRN!P=U&9R?A&
    50Z-X2TJWO-&:"]T(7$
    M<DEE&MEB6W ! FQ2)<?\L_[W;:;'BB2Y2^O8A#:3:A&F@,907A69SJ$F%/
    M[$W`D8#$;CDM@8W-#\7FD:CISRZG!/8Z9I\FGV4*VA201L8<&1_,(=@(5&
    M0J@DDX'2I-;\+S:G=WMW;W\=O/.E@(_,MS(J-:W#S@D!U+!B^W&1C&<
    MX@U_7O">D7-UJ$VFW[R6]P;1K>T>`1S1023 .IE?<C+$W(92" ,'<2O0:_J4
    MVE:=%<0+&SO>VEN0X)&V6XCB8\$<[7)'OCKTK/E\-7.LCR_$]Y::A;HDBQP6
    MEJ]JN9(VB=F)E=B=CNHP5 WL2"=I6.[\/:[J*V]O>^(8'L[>[M[E1'IX2:;R
    M94D"ROO*G.SDHB?-@C"@H0#F])UO4O#>A>;J6KZ-'!>:Q?VD,LULT$<,WVFX
    M=I)':8@IB.3"``DLB[QR]=1X7\30ZW<7M@NHZ;J4]DD4CWFF,# ZR%PHV[V*
    M.#&P[FXVMGYMJQCPM>1RE8-3@2""[FO['=:%I8;B5G9R[>9MDC/FRKMV=K
    MC#!E#UL:9;:I#YKZKJ,%W(V BVUKY$: 9YP7=BQSR2V,!< ')8 T****`"BB
    MB@#G1;6ZK/-Y697GEW$'&?WC#G'7I61=Z7'*PFM"]K=(<I(G8^^.HK?MH_,6
    M4=OM$O\`Z,:K'V(`9Q773J*,4F<52_.W$J&M9DU6SD2Y4)>VS7.@]>S?0_
    MXU+61I2B#Q[J,41^22T1Y1Z.#@?I_.M>N/$)6AV4W>-S6S4%S>V]G%YEQL
    M:K'K]/6H;VYE1X[>W"?"06ZHQEO?J.*QM2@@L(FN9R9YCQOD.2?8>GX5
    MM3I\[2,JE3E3?8==,;:VW.EE=S1+]YU0#CV!.35<G;>,9]5FECU*/4;!FW
    M26B1L(XIXP<%@X8GH<>A!JCJ=W-=9#MA/[@Z8E<O):ZQJ.L6=CIL9G\I_-
    M2/=@H"""!D\#DUUXC!*G3]HNASX;%.I-Q9VUAKVHW.IC2K>YN+CSN5C:0<<'
    MJ_7T/X$5V6D>'C9SI=W4WF7C(5.%7Y=OX\5F#?!AT%WO[43:EFSC[L2]
    M2H]<]S]['%<'-H=QD5POCW49-/M;58[AX/M%Y'"[QL`^QG&[;[XW=NN[JO
    M)/%%W]O\<3";#6NEJ&1.,&4YY(]0`37GUWRPYNQK&?+=F=>II>CK_:6K3WFK
    MSY#6EM?,"$XZLHXW?I['K63?ZOXQU54=+2BMMH\M8$VJ%[8P?2N>U.DUC4
    M)F%@>% [#M77Q>)KRRTYFBTN$P0(&32X9N.>,?6O)JRJ))V4GYGSV(Q,IR
    MU.>>7Q=:GS7&HI@Y)EEP/_'FJ4:V=3B6/7;09R%2]!4%&QD`LO3@9KL_$6HP
    MZ+:MVS2L8(_+VQYX&8U
    M).*XRCFEL9X[>)Y)70JJHN2<\5U'Q%N88/&VHF1P#ZX[_ZM:E\%7DTV@ZV
    M\$"([*$BF>(.RG!Y'XD<5=_>U//2YZUO,\:FMY[6X,,T4D4R]4=2&'X5&22<
    MDYKV71=,N-+\*ZMJ-S;6]]XADE)BO)BPPN% 7Y@,#K[>]9]GHEI9^"KCQ!>Z
    M.VI^(B9R\(VR1X$?%R.G/%="J)['?8\IS2YKT>'PCHUAX3MM:U2XN-0U
    M"4JMA&K1"%B6P ?H.IZ55L?!\6EHMSJ*^:YY5!RH_P`:;FEN"BWL>S?"0$?#
    M#1P00?WW7_KL]>#?&(9^*VM?]L/_`$1'7T9X$<2>#!E38/WF%]/WC5X'\3
    M<3_&/621D)Y!_'R(\56'@ZM1174FH^2;Z%3PX1@O[L7.H#,$1!91W/91_4
    MU[M97R6]O';VL:0P(,(B# `KRW1$N(_"^KZC;RQHNEI#(T3QEO.,CE.H8;<8
    M]#GVKNK.RND\6W_AV;6K6">VV^3(VFR.+@>4)'Z284J".">YV_X
    M'9Y\9SE[W<Z(ZD,[JRM::SU>Q>SU&!9H6Z9ZJ?53V-9NFWESJDDYBU&RCL
    M4N(K:"ELY0+J64`HHBSN0<\L21R#BJJQWL`@"7UE=K)J*Z7/)#!(GV:Y)&
    M5(8_O% R=P(SC%1%4N:ST&W.QXMXL\,G1;^40G?$/F4@8ROKCM[BO3?V<_\`
    MF9?W7_VK6#XLC>/4;O3YW6:2SN)(#*J;0X!QG&3CZ9-=)S]#]GNO%,793:
    MX^G[VN3,<,J<55CM(VPU5R;B]T>W4445Y!V$428NA_)V[M@\POG?@'@GC'
    MT&<U9/C/_D2=7YP?L[?@M6M$FBX?R=N[8/,YWX!X"YXQ]!G/M69XLMYK
    MOPEJ=O;QM)-)"RHJ]22K8%$MOD;89VK0;[K\SR+P_>Z7K6@V_AK5;B2PF@G:
    M:RO$&4#M_"XO0_;'.IX.CU6U^$UIJT[RW<<,R2.SEMP"?03VQBLC3];\
    M-S:19V>OZ=>"XTYF$3VF%,RYSMDS[C%+8^-D_P"$]G\1WENXCE1T6/DHI0
    MH]!S7(I)6=I]=.A4G[6,(O5/LU=M6<>NO4O:!J3KX(\47*?+,@A3@\[6<@
    MC/H>E6K'4&N/!WAZ5LDQZT($'^R<$C\ZY3PQKMKI;W]GJ,$LVF:A#Y<Z1D;U
    M(.58>XY_.KNI^(],SHFGZ3:W"Z7ID_V@M-@R3,6!)/;/'ZU2J1MO_5R:F%JN
    MHXQAN[W_`.W;6^\[?4]5TPYXQU359=;::\PZC3XX&!W,H #'IBMX7,9/![
    M2'&6N7) ^IKR#Q'J<6M>([_485=(KF7>H?@@8'7%>Q?#&VGMO!D8GA>,O*9%
    M##!VG.NG4YZCMMJ<69858? Q<G[SY=[image)Z';VYNQ R0IX]:<WTS^)9[
    MJ[4-?2W#R2C<&V\G`_*O;O%>L_V!X3U/40&QP%4"G!,0H_4UX9;66I7 6>
    MXO9H2_(CMFVHZ]1R>O4FMI5XTHWDSPL-@ZNDXT^AZQ\(;L7D&ON.-MZJD8
    MZ805Z57FWPAM);/3]6269YF:X5MTAR<;?7\*IZ?HD?Q0\0^(;KQ)-I.DZC
    MI=IIL,S11DQD%I)-I!8DE".1C!]JUIR4XJ2,U5*;IRW1ZK17E6H:)'\_
    M`!#X>NO#4DT6DZMJ,6EW>FS3-&#(25DCW$E2"')Y.<CWKT77=3_`$\/:GJ
    MWD=]AM);GRMVW?L0MMS@XSC&<&K,S0HKFX/"1SQ27VNZS<:H$&^]CO9(5,
    M@'#"W5O)`''RE"#CYMV233E\17%AJ]_;6EC/?7%QK:V,<<MV%2,_8$FW+E?D
    MC&WY@-QY=AN)"$ ["BN??6=8,JZ?;Z78R:ND0N+J(W[K!#&S.J8E\G<S-L;
    M"8&ULD?OSSJR:?XKU?4JVGC9MTQ1;?9#+)/=(D7#;=Q=E7.[:"<EL<T`
    M=A16/IK7C:B--U>R@L[Z2)KB 6UR9XY8U*J_P`Q1"&4NF05QAUP68+L4 %
    M%%% !1110 4444 9=CPDO_7Q-_Z,:GZGJMII=FT]U(% 'RJ/O.?0#O67%H<U
    MS<7,6I74(DN)<QHWRC#D<#\*LVGABS@N1<W#274XZ/,VZK797,E!ILK^%;
    M&Y'VS5[Y"EU?N&V'^!!]T?E_2KM:X&!@5D5C5=W<VBK$=_*8=7A<]&A8?B&4
    M_P"?I61XAN1)I<\!@<OT_.NEOM.AOXE24LI0Y5T.&4^QKR_P`574]O;7-I
    MYK,8Y)(]QX8@8 SCV->G@TIR2ZGGXF+7S,F[U*(S>1"&FF8X"1C.37<>!O"E
    MSIT\FKZD/+NY4V1PC_EFIZY]!5>6Z->C3-7L[X@E8)5D;'=0<U]#Q2QS1)
    M)&X:-P"KR",9R*US"K.-H=&:4,/"&O4FHHHKRCK,BO!=<E9-=\4D#B[FQ^
    M" C]":]ZKQ7Q?:FR\;7:NG[J_P#WJX'WF&0P^N,'\#7!B%>!4E>+7D>9V%RJ
    MSEB.`:ZJ>_1O#]P,J"T1`]<9_P#KUQJZ'J+ZW/86PB:1&&T/,D>\,0%QN(SG
    M(Z5J1:9K$;^3/8P2QVZA[A1>Q*-H<KRVXXYXKEK4(2:E<\'$82,I)WV/1OB"
    MPC\.V[<9,\7/OEN?T_SV\CU&Y78Q7:6SW%>@ZKXFO]<TZZTNY\,0%59(_-&I
    MQKL<_.FUONL>^!GOGO7GZ>&-:O('FCBMMB8#LUY"-N3@9RW'(-1@:*HQ_>-)
    MW[HVP]%1LVRQX,8O?WHY\OR,_CN7'\S7T5\,\#P#8;>GFW./^_\`)7AWA/3&
    MTOPUJ.K7( +'RTYSG;GI]3@#Z&O?/ EE)IW@G2[:9-DJQLSK_M,Q8_J:[H24
    MJD['K4UHV>9^,X;;XA:J=0OK>%/*_=,/G/[I.__P"NB'46NX%CL&AL[%!S
    M*^ Q4?W5[#W/Y56^(T]FOC/585MC<7[-$48H%$8\I.^?F_'IGVKCY0%S)=,9
    M749\I/NK]:YIPG-R]YHP=>-&5DD^_?[_`/(]#CU.6ZQ!IT16T+ R7#DA3Z[0
    M?O'WZ?6E?5(I!IMLGVF$-^\E=0T:'KR?XC[#]*X1YFQBN+^ZDM;X&(XD
    MW'>!ZA0>/K4^IZAJVGV=NJ2JEI.F8M@VMCCL0"O6LFIWW3OI_P`#_AK'1]8:
    MAS2BTOZ_J[N=5KVI6HL?3(6#20R3Y0X4?[6.!]R=0NIOB!<D#/7\*S8M
    M7GGTY9;""WA\Q263.6Y'KUIJY?\Q1GW-=47)TWSHVH5(S:<6>R 6^"M/
    M8]3YG_HQJ\0^(7_)6O$'_;M_Z(2O;?A]_P`B/IW_`&U_]&/7A'Q*N!#\8M:4
    MGAQ /Q\B/%>KEDE"O!LYL6G,DCI= M;B?X>^,?)MYG\RS5-L9.\B9LX]<=
    M\5W]QC_A:UQZ_:)O_2"*O-O#7BR[T3P[K5A9374=U>>2UJ\3`)$ZM\[')X++
    M@9 .<<UUB^(!=>-)=?AL;DV\DKD0%HQ+AK9(L_>V_>4_Q=*]O$T:LJDY-:.]
    MON1P4YP48J_;]1-&'_%.Z9_V&=(_]$Q4Z[_U%S_V/_\`2H;9KC3],LK0VCS-
    M#>V-VSQ2)MVP1HK+\S [B5..,<CD5G:EJ\@LKN..UDBN)/$3:S"TI0HJ[3M5
    MMK$[LXSC(QWK)4:DI:(I5(J.K,'QF!_PE>N?]A";_P!"KIO@7C^T/$V/[MIG
    M_P`C5ROB_4]*U.];4-/AOXBY>2:\BN7C:-7."!&5 )'WOO>U=#^S_,B[\4
    MR#H3:X^G[T4\SG;"P@U9_P"0\+'][2V/;:**=/1(HDQ<7#3MW;!YA?._
    M`/ 7/&/H,Y]JNVJAQ(I D8(/>LF]LA<W#>;"N[9^\,X._&> ,\8_#.?:KM
    MOJMC%NW74/..DB_XU2=F)GGGQ#'7VKS-5TJ/_2.LD7_`#U_R_G]>OC;J5)
    M0@@J2"IZ@^E?5C:SIKH5:XBD8(+K_C7$:SX\*:SJ3WLEP(W?[WE3JN?<]>
    M?>N>MAU6/HLKSQT(SKZKHJ\CPG.>HH'IP/K7LW_"MO"/_/[+_P"!2_X5
    M-:?#[PE:7D5PGS#&P8+.KJ?J.,_P">O2L/JLNK/6EQ'A;:)_<<_P##[X>O
    MJ#QZGJ<16 8:*%AR3U#,/U [Y!Z=?9I8DAM51%P`W^-5X=4TR",1I<Q!1V\Q
    M?\:2;5K"2,MU#USS(O^-=T(1IQLCY'&XRKCOM)_)=D9NOZ$GB30+[2F;;Y
    M\6%)[,""#^=>/0W&L>%V_L[7/#\UZ(OEBN('"LRCH#G@U[?#JEG$Y;[5`>,?
    MZT5(KV$G$DMLP]Y5I2ITYJTT9T<15HN]-V.8%]\VH6FI3'3I+%?-15CD;<
    MS#!8\?4?A4$NB*/!?B'5-0\+:?#K>EZM,UY<Z?-=""2&X)^9HW;Y<-G)!'
    M\( ]@NM66UM]1OK$0.8HH% !W+R[#MCL:P_$ZU/_GA9_\`?#?_`!54IPII
    M16QC4J.<G*6[(XM%\4>-/$.EZAXIT'1-+TF9;RVT&Z$\DUP#\K2.ORX7&0
    M`/XB#[=[?V-OJ>G7-A>1^9:W43PS)N(W(P(89'(R">E<-_PG6I_
    /_`X;
    M_P"*H_X3K4_^>%G_`-\-_P#%4?6($7-V`>,K:WBLG&C7KJ@1M4DFDA9SC_6&
    MV5",C^Z)0&QP4SA8_P#A&[S_`(2/^T?,@\G^V_[0V[CN\O\`L_[-CI][?SCI
    MM[YXK&_X3K4_^>%G_P!\-_\`%4?\)UJ?_/"S_P"^&_\`BJ/;P"YTM_8:E;:S
    M)J^D16ES/<6\=K/;W<[0KMC:1D=75'(.97!4J<Y4@KM(;/U/PC-K4VH_VC-:
    M2)=V5A%_J"4::WFEE.^)B<Q,SH"N_)&X9'#5E?\`"=:G_P`\+/\`[X;_`.*H
    M_P"$ZU/_`)X6?_?#?_%4>W@%S9\-^'_[,U&2Z_X1GPYHW[HQYTP;Y)<D'E_*
    MCVJ-OW<-N)!RNWYNHKS[_A.M3_YX6?\`WPW_`,51_P`)UJ?_`#PL_P#OAO\`
    MXJCV\ N>@T5Y]_PG6I_
    /_`X;_P"*H_X3K4_^>%G_`-\-_P#%4>W@%ST&
    MBO/O^$ZU/_GA9_\`?#?_`!5'_"=:G_SPL_\`OAO_`(JCV\ N>@T5Y]_PG6I_
    M
    +/_OAO_BJT-#\67^IZQ!9S16RQR;LE%8'A2>Y]J:K0;L%SIM._X]7_`.N\
    MW_HQJMUCVNJV=LDL,L\:NL\V07 /L8M3_VYI__`#\Q?]_%_P`:OF15C1K(
    MJ;W-/\`?FOXO^-4?M]G`,_<'_?P5$VGL-&[FO)_'ML8-8N/,^5@"6,
    MG@'C!'UXS7HO]MV><^?!_P!_A5:]N](U&#R;P6D\?]V213CZ>E=>&Q*HSYT<
    M]>C[6/*>$(C/(D<:L\CMA4099CZ #J?:O<?!=A?:9X8MK74#B<981DY,2DY5
    M33=.3P]I)9K&"R@=N"ZRN(],GG'M6A_;=G_`,_$'_?X5>*QJK625C2,&M1
    M67_;MG_SW@_[_"CW;/_`)[P?]_A7)S(NPRO+_B';I_:VGW-U!/)9QR288%
    M8LI,;@= 3][;VKTC[?9_\_<'_?P53EDM)&)^U6C<DC=(#_.N6HGI8VINQ\]3
    MSVDFKZ;<2OMFM+B-WF\EUR@()^4KGCKC'\Z;9WT-IJ/B6:66.&&_<O;2SVTC
    MHP\S<"<*> .N>_K7N&L'= UVV$-Z;)@,[65P&7CL1_OWKD;CX=R6TH?2?$
    M=F%SG9=D,/S&&_6N>5"\6DOZO?L<U?#QG)RB>;:=J%G!-<11ZO9W<$]PLLMO
    M<6$AB8$?,5 4E2"<#&/K5RUT^"WT[Q#'Y,]E8WLT!MQ-$PQ&KDDEB,*,=,GF
    MO14\,Z%5!K?AV(`@ETB9F_ ,2,_A6C#X)TV::*XUC6!J4T1R@FF78GZ@&T
    M?7%"I3OKM_7DC*.%OHV<%>7-EJMO!8:;#<>5$\)LXQ"ZAL2#<6)&,$9(Y]^_
    M'NFGC;I\`YX0=:HQK8Q@!9K$`= '`Q5R*]M$C"F[M\CTD%:T8<FBO8[96Y4E
    MT/%O&UM')\0]<F,JK*B0^7"[A/./E)T8\"N;6U6.RNKB54M[MC\D$<ZSB3US
    M@?^=>M>(_!>GZY?W=]#K<%O<WHQ:11*$"H%PH#KUVYYSUK#_X5A&RA7\6V
    MN.RU"D_13BE*C)NZ9QR@TFE!-ZZG 0WDUM$L,,DROC)BBE(53^>!3+N&.W
    MN$GU:[B2>4919Y>NW]=CI_A]_R(^G?]M?_`$8]?/'QB)7XKZR0
    M2"/(P1_UPCKZ2\/6]GH.AVVF_P!I033N_>;@N<L6Z9/KZUY+X^%NJ>*?&V
    MH:U8ZOHD=M<^7L6>Y8.-L:J<@(1U4]ZWI>[N3/5NQYKI.L"15C<XE'Z_2NIL
    M]9DAQAJ8/@;X@!R-;\/9_P"ON3_XW5#X2>*H1CW?#KC_;NI#_[3KZ'"YPH
    MQY*VIYU;!7?-`>?$4F.OZUE7FK/-G+5M'X6^)MN!JWAP'U-Y)_\`&ZIW'P?\
    M4W(OKWAX?X5NI!_P"TZZIYSAXK]VM3&.!J-^\<'K&K"0-!"V<\,P[>U>K?
    MLY_\S+_VZ_\`M6N:_P"%&Z__`-!OP]_X%R?_`!NO2/A/X-NO`G]K_P!J:GI<
    MWVSR?+RSEL;-<[E7^/7O7S*Q,L1)SDST:5)4U9'J-%5_M]G_`,_<'_?P
    M45QFQ8FNA(F:(/X^Z@?;G\3P;<7:>?LC>39@1XE \PG.<9/&..3ZTZJL
    MIZ?:WL%E<7UM#=7'I@DF57D_W5)R?PIW$6);B[3S]D;R;,"/$H'F$YSC)X
    MQQR?6B6XNT\_9&\FS CQ*!YA.)0/,)S
    MG&3QCCD^M/$UQYLJDL$0@_F9W]<X'7CCKZU534;&2Y-LE[;M< E?652V1U
    M&,YXP:LTE)/89QS1:<VH:]>ZLT@M;)//=UDD&Q09"QPAR>%]SQ5O3=/T#5?-
    M^SVFIIY>-WVJ.[M\YST\S;NZ=LXXSU%1P6BW]SXFLW@2X2X@\IH9)&C60,91
    MM*"5!SC(!(JSX;MKV"XO&DM]0M!EC$-MJ-W]IF$H+8_S),(08@!NZJQV
    MC.68BU_PC&D_
    9O_ J7_P"JAING:%JK78@MKU?LTJQ/YTTT9):.4?*6R/
    MED4$, 001BN=TCP9>:;9:;Y.E0V]S;6ND_-$8U9)A,?MK @_>:(*'8??``RV
    M,5:TPMJL?P^UK1;F)>[O;.."+S) 5#?8((225SP'1A^&1D8RP-2)K&7PCJ
    M%UIT<R6EU#;S1>:Y8NAD.U^22 R@, <$`\@'(KA]%DDEL96D=G87=RH+')P)
    MW 'T``'X5Z#<:A%JOA>^OH5=$FM[<F.0`/&WFL&1P"<.I!5AV(([5Y%I\OB.
    MWU9[>+3X38%KN16ED:/<QN"02=C$'!X&,$$G)Z#&JK_UZD2W-S6I)(K&)HW9
    M&-W;*2IP<&= 1]""1-;>FPI<:I:0RKNCDG1&&<9!8 UQ&H2([C5DMY=/A%
    M@&M)&:1I-K"X!)!V2WTV9?52:5ML<<Z.QQG #`FLK6M<1
    MD]E<.L<UG';(Q \Z%GRGN0Q;('7`P3CJ7^S93]GMC&B7$EV]N6+D_,-@P0
    M., MU&<Y/H1(+W=9)KR.Y12#Y,*OE_8E@N`>F1DC/0U8M]11I[":YE_>)?
    MO<3';T!,9SP/]EN!Z4U;J!7&F90R?;+7RT(65]S$1L<X'3YLX/W=PXSTYJ/^
    MSY%F=))(XXT"L9FSLPPRO09Y'(&,]<@8.$CF1=+N(2W[QYXG48Z@X/_`$/
    MSK0748BTD20H)([?$LT(D0-''M((GN3R >GH<A)("HNER%))7G@C@0K^]9
    MCM8-NP5P,G[I&,9!Z@8.&C379BPGA-N%+&X&[8 "`>V[.648QGD'H<U8O;Q9
    M;"2!KF.9P\6WRH?+0*/-)P`!W<=0#DGKC-):72)8PPBY2&022EO,BWH01'@,
    M,'(4]CR!P.H=H@0"T58[HAX9U2 .LB.0!\5<X(SGDC! ZY],G]FO\`ZOSX
    M?M7_`#[?-YF?3IMW>V<YXZ\58FN;8)=KQM)):A&>,HDC:K<# Q\H'8<@
    MN2[[1;?VI_:WVE,?]HS;6W[MV=N<;<9[YZ<XS\M%D!7;3/+""2\M4D=%=(
    MV9LD,H(R<87KCYB/7I@U2=&C=D=2KJ2&5A@@^AJQ?S)/<(\;;E$$2$XQRL:@
    M_J#1J4R7&J7<T3;HY)W=3C&06)%2[= *M;7A/_D9K/\`X'_Z`U8M;7A/_D9K
    M/_@?_H#4X?$@.RTFSM;AM1>:VAE87LH!= QQQZUI?V9I_P#SXVW_`'Z7_"JF
    MA]-1_P"OZ7E:M=T8JVQ15_LS3_?&V_[]+_`(4?V9I__/C;?]^E_P`*M457
    M*NP%7S-/_Y\;;_OTO\`A1_9FG_\-M_WZ7_``JU11RKL!5_LS3_`/GQMO\`
    MOTO%']F:?\`\-M_P!E_PJU11RKL!5_LS3_P#GQMO_2_X4?V9I_\`SXVW
    M_?I?\*M44<J[`5?[,T__`)\;;_OTO%']F:?_P`-M_WZ7_"K5%'*NP%7^S-
    M/_Y\;;_OTO\`A1_9FG_\^-M_WZ7_``JU11RKL!5_LS3_`/GQMO\`OTO^%']F
    M:?\`\^-M_P!^E_PJU11RKL!5_LS3_P#GQMO^_2_X4?V9I_\`SXVW_?I?\*M4
    M4<J[`5?[,T__`)\;;_OTO%']F:?_P`-M_WZ7_"K5%'*NP%7^S-/_Y\;;_O
    MTO\`A1_9FG_\^-M_WZ7_``JU11RKL!5_LS3_`/GQMO\`OTO^%']F:?\`\^-M
    M_P!^E_PJU11RKL!5_LS3_P#GQMO^_2_X4?V9I_\`SXVW_?I?\*M44<J[`5?[
    M,T__`)\;;_OTO%']F:?_P`-M_WZ7_"K5%'*NP%7^S-/_Y\;;_OTO\`A1_9
    MFG_\^-M_WZ7_``JU11RKL!5_LS3_`/GQMO\`OTO%']F:?\`\-M_P!^E_PJ
    MU11RKL!5_LS3_P#GQMO2X45:HHY5V`R*\6(=Y91?&/PZEQHKW.HC[/\`
    M8I5URHFS*0GFKY$;9-Q4G(Q]![37GWBGX;7?B/QQ8>)DUR&UDL/)SP-8
    MF0?NWC>?-&<L3TQQ@>YRB]2F>@UGZHTZ&"4RF3X]S7IC.)2F/X3V'4G&&P
    M/EYK0HK.4>96&<VAO)]=N['4M+TN/P:D*O;7&Y53<V[YE. `3N'(/\7&<D)I
    MZ.T_V9TD:XDA1RL,MS'Y<KJ"0-R_3'S'!/=1U,T.E:=;3++!86L4B]'2%5([
    M=0*MTY/GDI62LK:?U_7<PP]%T4TY.5W?7OZ[(S]+;1(9KF1[W2]FN&CD1K
    MA0P(D"JNW/!S-'[YE7^\M6K/5]%O(E<:C:7D(HN4.\;D"$>NX2PD>OFIC.
    MX9="[R:9]A@9DNEK@*X./42$%\^VX8`Y)(Z#)&RB)%&L<:JB* JJHP`!T`
    M%;J*L7=\QA1ZUHCW:0#49A-M,$D=PKK(&$>.1]TGS8L9X/FQX)8J>/4="E
    MV>7JUF_F;=FVY0[MWE[<<\Y\Z+'KYB?WAG6=$EC:.15=&!5E89!!Z@BJ7V>X
    ML>;,>=!_S[,P78/^F9Q]?E8XZ8@8I\J%=HRVBL=?34+:PU"&22"W)EAAK._P"$`_ZB?_D#_P"RKI.YBNM3NGB8$,2LK593NDXD
    M`C@@\]B#WKAM/U/Q3J$4/DS:S)(UI9W+;5L0")&;S&&1T*J=@/((^;C%8U>1
    M-<RN=N&P;Q,934HI*V[MN:O_``@'_43_`/('_P!E1_P@'_43_P#('_V596H:
    MGXIT^*;SIM9CD6TOE=RV) $;Y;' Z!6&\#DD_+QFNU\2ZE-HWA75]4MUC:
    M>RLIKB-9`2I9$+ '!!QD>HJ81IS;7+:P8G!/#QC)R4E*^SOL<_\`\(!_U$__
    M`"!_]E1_P@'_`%$__('_`-E6H9=;TB*;4M;UK2GTRUB>:Y$&ERQN$5220WGO
    MTQG[ISC'>K$/BC29[.YO$FG^RP;?WS6DJI-N.$\EBN)MQP%\O=NW+C.X9T]C
    M#L<=C#_X0#_J)_\`D#_[C_A`/\`J)_^0/\`[M@^]#2PNVXNY+."W>)9O
    MMMO+;-'YCA$9ED56"%CC?C;PW/RG$?\`PFFB?<WWWVCK]D_LVY^T[?\`GIY/
    ME9Y>>-W;GC.>/8P[!8R_^$ ZB?\`Y ^RHX0#J)_\`D#_[N@O/$.F
    M65O:SM/)<)=IYEN+"2Z:5,`[U6)6)3YE^;&/F7GYAG0@GANK>XMY8YH)4#
    MQR1L&5U(R""."".<Y\Z'KYB?WADTK_2-1N)/X5IH01_?>4LP/T`C(_WCU[;57RH4=;F =>
    MA:2V6'6])E$[JH8/#I4\2<Y,L('KYJ?WAF/_A(HWBG>'5]E8\E4Y\_*Q
    M,NW$G.3/$!C.?,3\*W9H/-EMWW8\F0OC'7Y67'_`(]E$,'E2W#[L^=('QC
    MI\JKC_QW]:.5%&=>CHT6M:1-YDD2QB,[BP['R.9(H9(C'3M([XRH!;HO;J<')RH#7Q,
    M&LKB==2TQW09AAC(=I\K&R!<2<EO.B QGF1<$[AET?B-);5Y8M7TB5P@V1QY
    M)D<A,*N6&X'SH=K#KYJ<?,,W;JR6^N[JP=R89"D\RCY3@KM3!YSAHLXP.HYP
    M"&M/8230W8FG0RW$/D[DCVJH;'!)Y8]_2CE1*U9GKT,ES!%%K>DR,FY7
    M7!!),6T#]YSN\^+'KO3^\*2UUZ.Z"%=:TC#L57!R6RR!"!OY#"6(C_KK'C.X
    M5M-!NO(R-TVXZ[BIS_X[^M5-3D5MD'VN*,GYF@,1D:4>FU2"1USCKCGC
    M.3E11DV_BF"=[1?[6TX&XBC==L9<;G\O:N0__3:+KC_61]=PJ:/Q`DM['#'J
    MDM%(@,<JL#O)\K:`!)W\+'.3O7CYE)MW-RD\)BEO/(BDC\N4SVS1J<]=A;
    M&"<G@[NG3@YT&@W7D=QN^Y&Z;<==Q4Y_\=_6CE0&,FO0RW,<46MZ3(LB!@ZX
    M()8Q[ /WG.[SH^G]]/[ZYC_X2*-XIWAU?2I2F/)5.?/RL3+MQ)SDSQ 8SGS$
    M_O"MV*#RYYY2VXRL",C[H `V_3.3_P`"-12V/F07T?F8^U9YV_=R@3\>F:.5
    M`97]O1O-%';ZUI$OFQ[D8'Y23Y6P9#G[WGQ8_P!]<9W"HY/$D2EO*U;2YALB
    M,1C&[S#(4 `PYS_K83QDXE3 ^9<]!/*L,#R-'$`/OR?=![9Y'?WKM[@PP2
    M*;B21V(8316,A#GU)Y# \=,<=,<8.5 5H_$5O<"T:WUK2Y5N'"J=N" 0I4X+
    MYY,D('KYJ8^\N85\4P$P8U;3F$SL%,<9DR,H$(VN<[O.A([$2KSRN=6&!;F,
    MSP7D,LPG\TR(NZ/=LV8P&S]WWZ\^U3K:SPP*L%PBON9G+Q[E8L=QXR".2<<]
    M.N>M'@$>M6\NSR]?TA_,V[-N#NW>7MQ^\YSYT6/7S$_O#)'K5O+L\O7](?
    MS-NS;@[MWE[<?O.<^=%CU\Q/[PSK6\*VUM% A)6-`@)ZX Q4E'@.<_X2-X
    MIWAU?2I2F/)5.?/RL3+MQ)SDSQ 8SGS$_O"G_P!O1O-%';ZUI$OFQ[D8'Y23
    MY6P9#G[WGQ8_WUQG<*U9;'S(+Z/S,?:L\[?NY0)^/3-3SRK#`\C2QQ #[\GW
    M0>V>1W]Z.5 <_)XDB4MY6K:7,-D1B,8W>89"@ &'.?\`6PGC)Q*F!\RY?'XB
    MM[@6C6^M:7MPX53MP0"%G!?/)DA ]?-3'WES9M[@PP2*;B21V(8316,A#G
    MU)Y#`\=,<=,<8FA@6YC,\%Y#,)_-,BNCW;-F,!L_=]^O/M1RH#+C\30N8S
    M_:VFE)-VTQJ7)>)4P`3O$\1&.TB==P-6H=:AF2(C7=&9I NT1D,"6\O&#Y
    MG.?.BQZ^8G]X9O"PDB$3PSH)E\S+/'N4[V#-P"".0,<]/7K2[PHEA8LC0(
    MJ/)?EC&!C.!\S8P=HQQUY&3E$VD9TFOP^7']FUK2;B28JL*IC#%MFW)$AP
    M#YL7/?S$QDLH,D&M0S1PD:[HQ>0)@1L&!+>7C:?,YSYT6..?,3^\,ZMM9Q6N
    MYD&Z63'F3,!OD([L?QX'0= `.*GHY4))[LYTU&[9MFM:3M,@2$C!\T$1X(
    M'F=S-&!Z[T(R'7+(_$4<L"21ZOI3M),L:(O)8,\:JP_><@B:)AZB1/[P)U-(
    M_P"/3_KZN/_`$<]2?8?]%\GS/\`EX\[.W_IKYF/Z4.".L4S*37HYKCRX=:
    MTAPRQ-&X/#[R@ &'Y.)82/7S8_[P)A;Q-""-FK:;(&F2.,QJ7WAEB8,`KDD'
    MSHP,9R9$_O"MZE$5JWE16K-\JRRXP#]"1D]:HQ7/DVHC$SQLK9WFQE5,=]
    M^[ZDEMP]3WR<J*)K6:YO;2&[MKZSEMYXUDBD2!B'5AD$?/T(-%8LNCZ%<3/-
    M-JR&61B[[)T"Y/)P#G $T4<J K^+O$/"*%[S6OLOVK[-L_<9LW;G5/O8
    M./O9Z=J\]T7X[V5_JT%KJ&D?V?:ONWW/VDR[,*2/E$>3D@#\<UZ%XN\/?\)5
    MX7O-%U?9?M.S]]Y>_;M=7[D9^[CKWKYRU[X?ZQX6U';=1[H&DD6WFW(/.5
    M3C=@,2N00<'UK>E+!QPTW6^/6V_;3;3?N:0C>:YFE'2[;2TOYGU%:74-]907
    MEL^^">-98WP1N5AD'!Y'!K(UWQ%_8VJZ'9;;(_VI=&WS<7GDLF%W95=IW]-N
    M,CYF0?Q9'!?!6]M'_M2U2[@>X\J%O*652Q"[@3@'H"P&?<>M=?XL^T_\)%X/
    M\C[;L_M-]_V?R=O_`![R_>W\_=W?=_AW_P`6RO/IRYHW:,X3YU==W^=AOC/Q
    M/?\`AJZTN6$'3I9`+R4V<L^T&:%`H,9PAR2,"P.2@`&35GPWJLZCK&LV
    MI6?DVUKMMG^QRP[AYLRXW.2)/D2)]RX'[S%5?38'\57.L3^(TN["X@LVBM
    MW:W96S+*8>D>=F]U,;!MQ8'); KJX9XKA"\,J2(&9"R," RDJPX[@@@CL015
    ME$F@V[HEU<2%299W6,CM&K-@'_@1<_C^`UZHZ1_R#_\`MK+_`.C&J]6RV)M8
    M***8%2/_DW/_7"_T2O-M!?5="B5K.S\EY+2RBE4>'[GE@SB0L5(W.BMN
    M?Q\`8Q7I,?_`"%[G_KA%_Z%)5NLIT^9IWV.W"XSV$)P<;J5K_U3/*]>?5=
    M=B9KRS\YX[2]BB4^'[GABR",J6)VNZKN#?P<@YS7<>-()KKP+XAM[>*2:>73
    ME(XXU,[&)@``.22>,5N44Z=/E;=]PQ6,]O"$%&RC>VW7T2.+\3>"]!MO"&
    MNOH_AK38M0.F720-:6"6:%UPNU<Y.<8'7.V/%$US#96PC%V.2X"7\EE&
    M[SI!L<_NP@YB-"5!8*[$;2-Z[E%:'$>7KIS2ZEJ4VFZ?KALY)=#,<FH_:)
    M'E\N_=I"OG$R*JCDA@N,%L;6#-VEK!,OCK5KAHI!`^F62)(5.UF66Z+ 'H2
    MRDCMN'K6Y10!Y?I>F:CI.G:)?7-YKFFPR>'["RD73;%;B1)HA(2LL;0R.O$O
    M! QE7#$'8#W'A>S2RT&*.,WS)-.7OT5)G,DKR%F50`NXL2%VJ0" 0""!L4
    M4 %%%% !1110`4444 4-*ACBAN'1<-+=3.YSU.\KG\E'Y5?JIIW_`!ZO_P!=
    MYO\`T8U6Z "J+8O&D:23;91Y4KP!(02&W?[((QVSALY&*GO9FMK"XG0`M'$S
    M@'ID`FL37LV>GV=E$Q\H#:23R0H`&?S_`$K'$5E1I.H^@TKNPVX\1>4PBLH(
    MQ"GRJ6!P1VP!C SQ1%XBMY8I$U2&(08+,VTLH YY7GTE7 ^(=2C;1=3MHX
    M[KS3!+'DVDNW.TC[VW;CWSCO5U;Z'49A:Q)<`##R^;;R1C;V'S*,Y/&.X#5X
    M$<9BN95&].UM%R44K<] TR.:R8"Z+;KQO,^8[BC[?]63WPBJ W?:Q)R16K
    M7/V4[R&9W<Y-J2Z9[[,.H/MD8E=!7T-&JJL%474SY>70JSO)+.MM!(8V #
    MRN ,JISC&01DD>AX!Z'%9E[JT&F%K:RA1I,Y=CTW=\]V/J<U-.\.DW]TAQ
    M),X..V&\L$?@H/UKB[N]CLPN])W+9VB"23IZ[%./QKSLQQDZ35GNRX13U9
    MTT'B:82#SX(S'W\O((]^3S6J#%:P+=VC@60!:2-0-JK@Y91C((.,C_>XS7EN
    MCZK!#8NLL=X6-S,[)0O0-@'CV(((]CSS7!
    MV%Z<Q7<'F@Y421M&>#C!4@'_P"M7<'Y-87'_:W.[/;8PQC_OX?TKT<OQ<J
    M\&I[HF<;%NBBBO0((YYEMXC(P)Y"@#J23@#\20S[B6/3H4N[YA-=X^0<?<
    M<A..!SUZXQDGBK,_SZE:1GHJR3#'J %_+#G]X_7;TB]N9IO,98W 1QLY !
    MP,* 3[\>YKBQ^*>'IWBM7HBHJ[-)O$UV6.V&`+G@$$D#\ZT[.ZMM7S(F;>\0
    M8W)C>%I'(YZ$=??!KS&75X/$@M)62Z6(6TR<V<P.YGBQP5SV(XZ<9/(K7L
    MKG[7+YX298HGB6-X]_KN! )4@XQT()SZ#RJ.-Q%*2G5=XO?_@%2L]([G;V
    MMY-JT1C4-%&AVS3(<>8<`_NN<A3G.XX.",<G*Z4,,=O$L42[4'ODDGDDD\DD
    M\DGDFH#\FLC_EM;G=GML88Q_P!_#E6ZCN8I6U>X445'/-';6\D\K;8XU
    MNV,X`&2:114T7G1;.0_?EB$SGU=_F8_B235BZF:&(+$`9Y#LB#="V">?8 $G
    MV''-1Z7#);:1902KMDC@1'7.<$* 10/GUAL_\L;<;<=]['.?^_8_6F]R8:11
    M4OJVTC$CYNQQC<^-Y7Z@<#CH!U]\FLQ?$UV&&Z& KGD $$C\ZP]1U *[75
    MP)F,C](HGE(_!02!Q_L"#5H1K][\5YL:V@50+*8GAI7'#;AQ6UI.BZ;H5H]KI5E#9P/*TS1
    MPKM!=CDG@] `!@`"K7D)ZR?]_&_QH$*@@Y?CUD;_&B[`NZ1_P`@_P#[:R_
    MC&J]6-IH16MJ5N5>",2RXG<#RS\;^('Y?3YL9/3-:5Y<BTMC-Y;2'<JA%Q
    MDEF"CK[FMULC.Z;)Z*QI-?6%RDMJ4<=5:XB!'_CU-_X22'_G@/\`P)A_^+J'
    M6IIV<D,T(_\`DW/_7"_P!"DJAXC\0)H=F_E02W5^\$LMO;1)DL$ +,22%5
    M5W+DEAU &6(!ETR]6_U"ZE5-H$42XWJ_=^ZDCO7/>*M%FLI-2URRAN;M9[!H
    M;N!;UU<;-[1M&"P0@&1]R,0,8*\@J]Q::N@.HTO58-5@E>))8I8)/)N()DVR
    M0R !BC#H>&!R"5((()!!==U/^Q/#VIZMY/G?8;26Y\K=MW[$;<X.,XQG!K
    MT'0Y8M4N];O4G@N;E(XHK8WDDOEPIOB0EB&DSY(!*C@G!=I/'?\`R3SQ
    MV"KKT4U,#H*Y^U\8Z/_PCVCZMJVH6.E?VG:1W,<5W=HGWD5BH8W8W 9
    M[CIFC_A#=Y^M<\'M[_P#'JY/P!JVF'_#UM)KH6FGO=V5@UG>S+&);=
    M;.%=J,QP0LOG$H#E2X@>8"P!W$I31>*M/TM5C\BXLKFX=B#N#1O J@@4444 %%%% !1110 44
    M44 9^F7"'SK<AED$TS*&_C7S&R5]<$X/<<=B"="N:?4X$CEMI(SOCN)6219X
    ME9&WM@@,V1U(Y'(X((/P^-C"&[AC:4YR1S1K@>Q<X/MDYQD=P,_:T]N9
    M$W:>IT,L23PO%(-R.I5AG&0>#61=V<NJ:7&"0;VW)5
    ;F'#?3/!'L1TS4T>
    MKRS('BT9T/1DEC(/Y-4,MU==]H@T^X67:%93)&5D )P#\V1U."/4=>!2J0
    MA6@X2V92E9G':G:RW&G7EH@"S20O&/,R`&((Y[]:328[B^5)C'FXN N$7LH'
    M'X<EO;/M6OKNK6$\0M[K3RF?*.8Y48JO ?)4]0,@9'7'%.T6K.UT>(6M@O
    MGQ((G,DZ)N9<!L%CG'&>E>*LO23BZBM?YV_I?@#FG46G3^OZ\S<2R%KIT6G
    MAI+A_P![CH5_C]P-ORY]2.F:UZY^WU@1K<71@EG=4!E=)8B%49. `W Y;'4\
    M]3Q705[=)0C!1AL@O<S6MEE%YI\GRK)F6+V!Y/U(?)/^\OKBN4NK66SG:&9<
    M,.A[$>HKHKW5%9=QMYHUBF98YQ$OSN4XW'TW=1_2J%YXAM#822:E8I((@3
    MF&>-B1Z@!LC..@)IK@Q%IU[>\E)%1GRARC)*NEQM/L\R5WF.S.,.[..O
    MLPKM=)LCIEK>W*GS&7"QC[V/3'J3C ^GK6-HNIZ7:VUM$!OM$,*JSO(H7(
    M`R1N;'4?6MMN]EF2:XTZ?'1)&54XQG.<DX)]N1QG!,83!1C5=64DWTL)
    M2M!(U.%K>TCCD(,F-TA'0N>6/XDDU'>?NI(OH(FR'_IFW!_ $2>P4_C7
    M;59D1G?39U51DL98\ ?]]57_`.$DA_YX#_P)A_\`BZ].52$?B=A%#7=,>"=[
    MN,9AD.6Q_"Q]?J?\/2N3AM7GU>/4\KL$,L('?:63;CL0=C'/^T.M=-=:WY5H
    M+"% 8)\0C=<Q!HDP=P4AN<*#@GN.K9 J6";1Y9TC_LBYCC=F1712R9 /"["0
    M1QV_E7D5L IS<J$EKT_,:G=V?0@TG3'OYPS#%NA^<GO_`+(_SQ73P_O]0EGZ
    MI$ODH??.7QZCA1[%2..[8UN)$$44)L81W0O &5`]SGOQWJA'K<=M9V^+&2
    M* QCRM\T:Y7 QU;/3'37=A<-#"4]7J]V.4KLW**Q/\`A)(?> \"8?BZ5
    M?$,;N$2V+,QP%6XB))]OGK?VU/\`F7WDE^\_=207?01,5D/_`$S;@_@"%)/8
    M*?QYOQ':?8KDW" NLQ;$! \9/TR1R<`$@''&=277+AI7MK;3I'N@,D&2,B
    M,''8;WX'!;MQR*MM-/IL3>=8/)"Z!9'EDC78 ,!1\Q^3G@$Y&2265GBL/"
    MO3M/IK_7D2JFONG&RP7 UFPN9&C9"LL3(1]PL PV\>B$$GUX`SQTNDZ8]_.&
    M88MT/SD]_P#9'>J:AJNBBYMY#ITP$5QF00<JR<8;'WF!X["ME]=4`0V\
    M*6\(&2T=Q!N'7@`G`O/TY!KRZ>!@Y1E5FK+MZLN,K72_K0V8?WH2S]4B7R
    M4/OGX]1PH]BI''>W6=I]ZK-#::20((=T1+JP*KM'!!/]X5;N[A;2TEN&4L
    ML:EB!U(%>Y?J(FJAK?\`R -1_P"O67_T$U6EUX0-MFM&C;&<//$#C_OKVJAJ
    MOB&6P:$PC;\<;C[1$<HSA6'#=U)&>V<\=:GVM-2LY(B?P,Z>JDW[C4(I^B
    M2KY+GWSE,@Y8>Y8#GM1CU]99!'':EW/15N(B3 ;VJ66]FGA>*32KADD4JP
    M\R/D'CLW^?RIQG&2O%W*N8.K:8]A.649MW/R$=O]D_YYK"1"FLS.V,2V\83W
    MV,^[_P!#7\Z[!]5F@7R;ZS,D#*M/"&;&#@C.#ZY&.W'<X']JZ*=9M633IL
    M"089"2T>,Y;&.#UKPZV7151JG))/HG4MST3_KL145TP\1VZ$6W"A1@`3
    MQ8'_`(]16?\`9E+_`)KOF5[3R,CQAXGM_!_AJYUFXMYKA8L*D42GYG)PH9
    ML$(N>K'\,D@'D-0D\.77QTO6I++73=)9SOO^PWZL&1X0FU-OW,/" -IW_-
    MRPR45[J6A)U?A7Q;:^*TU(V]K=6[V%Y):R":)D#;2<$%@.2,$J<,I.".A,'C
    MZDTWPR]\OVIXK=C+-!;&:-IT5&.TRQ*6A (#;!\NUB`Q-%%*VM@&>9>_\`
    M"O\`S/M-[Y_7_CWN?.V>;_J?N>?]S]WYVS?C]YC-/\ WTFI>&4OF^U)%0Q,9(R59%YRWM117SV(IP4M%_5PIR;NGT.E\'&8F]
    M,X0/B/A.P^:NIHHKV<&[T(LI[A11172(***`"BBB@`HHHH`***`"BBB@`H
    MHHH`\SU6\GM=8N]\:>0;A]I!Y/S'/MGV]/QPV[,LC"".(,&&YG?(4>F".<YH
    MHKYW$I?.EK>7X,<=;IEJQU )X;UJQO6"3B3;)T63,>``?[W'3OV[BIO![S
    M27L[16-G90>4J2PQ@AODDFC4X_O93DG/&!D]RBO8PZ7LH-+=!"3Y91OI_P`,
    M8D4UP\DMS'&ODQ+Y8\S.6VYW%?3)X_X"*FM;F..T9FW9,KX4#))8E@/Q!'YT
    M45XL81FN5K:WX$KH_ZZFAI,S3V=W*X`8V4V<=.H'?\BO0Z*];`)$DN[*
    M>YP>O2S(]HD(3<\]V,OG'$F>W^?ZXEY/.L$EO.J;IXV2,QYY8\ '/N1117%B
    ME'ZU:VO]?<3+&RP\MX[R>3$@1.!YF<L?:KVN:E&GA#2[T6L5R8LR"VG&Y7
    M\N&3.1W /.<''!QZE%5EMG*6FUC2[3NB:Q2>W\&SI)#%'#%,RQ0Q$LRXG.Y2
    M<D<'@8/\^<AKF[BC$\L48BSRHSN -%%1C$G7BFMTE^*E\4O5D?FSSZG]G$
    M96%!'N?IDG+8QUZ ?53^/3>')O.2V8KM87[JRYS@B%N_?_/XE%7@XKV]K;)?
    MBC%?#<["O.M1EN/.T& 1_\`(/B8[\I]***[<>E[%MHI;E>">4SM!.JAPN\
    M%.A%4Y;N]GBG>&-$@3()<?,<=<=LC].G/-%%>(E&W-9=/Q"3U2-S7YH4N-%-
    MM8VUT)5VB*Z3>$$LL(#MU.<MG/<YZYR5=[B'P7I;2HKX$7E+$#DIY7&1Z
    X
    M'_URBO;Q:3I._P#6JBWR)=O"85Y/<Q0QM<I$(S(A8IG*X8,<O`/2K!NJ
    M5Y?LZ1[(R5?JQ'7%%%>*7V*G9=?T(7QOY?J=7X:E$\>GR@8W07''I^]2M?
    M6O\`D"7O_7%OY445]%2BHTU%=$)G#7]Q>7&K7S1B`*LY3YLYX '\L51NII
    M)<Q$S"=%\M><LK!CC\ :*\:BZ\M-G<)?#8MVDUU'J%B+B./9)/&OR9R#N'
    M6EU.9I/%EQ!;VEE(SW$4JW4D6YU9&M4VA@#QEQGTYYYHHKLR])TG*QK!M321
    MH>(I;E;!1&K3O FXC.Q3EL/3O?":YDBU&$7*J&V.,ITVD;L^O\&/Q]N2
    JBN2:CO+7?]3*7PKY?F/_M"8\I92LIZ'GD?E1116;ITT[<OY_YFA__9
    end
    Hi Christian,
    Where do I find it?
    "Christian Bohrer"  schreef in bericht
    news:jrn8dt$m5b$1@cheetah.cadsoft.de...
    layer.
    Regards
    Harry
    To create correct documentation I would like to place  dimensions on a layer.
    Regards
    Harry
