EAGLE User Support (English) move + sign on polarized cap silkscreen?
  • Subscribers 189 subscribers
  • Views 523 views
rickford66
rickford66 over 14 years ago
I'm using Eagle 6.1.0.  I have some polarized caps on my PCB that have + symbols next to the positive pad.  The problem is, the symbols are interfering with other pads, and I'd like to move the symbols.  In the component layout in the library, the + symbols are on the tPlace layer.  I've tried smashing the component, but this only allows me to move the designator.  Is there a way to move text on the tPlace layer, or do I have to go into the library and move the symbol over to the tNames layer?
Thanks.
    e14 Contributor over 14 years ago in reply to rickford66
    Am 15.05.2012 15:42, schrieb rickford66:
    Although the part updated correctly, the + sign is still not movable as the designator is
    In EAGLE, ONLY such designators can be moved. To be able to move the
    plus sign, do the following in the library (awkward, but should work):
      1. Create your part with a custom ATTRIBUTE called, e.g., 'PLUS',
         being defined as constant (NOT variable), and which holds the
         text '+' in its value.
      2. Change the '+' text of your text to '>PLUS', effectively
         creating an attribute display out of it.
    That's it. When NOW you smash your capacitor, this attribute text will
    also be made movable. Unfortunately, this opens the door wide to
    accidental errors like moving the plus sign to the WRONG side or things
    like that.
    Andreas Weidner
  • rickford66
    rickford66 over 14 years ago in reply to e14 Contributor
    Before I placed them on the board, I ported them over to a custom library and changed a few things.  Amoung the changes, make sure the + sign is text.
    I just tried moving the text (+ sign) to the tNames layer and replaced the parts on my schematic/PCB.  Although the part updated correctly, the + sign is still not movable as the designator is.  I find it inconceiveable that this would not be allowed, as there will be times when there will be another pad, via, or other obstruction right where the + symbol is located.
    layer? Thanks.
    I'm pretty sure you'll find that they aren't text, but rather just a pair
    of lines.
    So you're kind of stuck with having to edit the components.
    My liberal friends think I'm a conservative kook.
    My conservative friends think I'm a liberal kook.
    Why am I not happy that they have found common ground?
    Tim Wescott, Communications, Control, Circuits & Software
    http://www.wescottdesign.com
