EAGLE User Support (English) How do I change all fonts to vector on the same PCB at once?
  • Subscribers 190 subscribers
  • Views 2737 views
autodeskguest over 14 years ago
  • dukepro
    dukepro over 14 years ago
    On 05/14/2012 08:22 AM, Chuck Huber wrote:
    On 05/14/2012 01:46 AM, Lorenz wrote:
    >> Chuck Huber wrote:
    >>> The "(>0 0)" simulates a Control-LeftClick at the origin.
    >> I'm sure you meant Control-RightClick 8-)
    I've used this a million times and we both missed the mark.
    It's a garden variety RightClick - No Ctl, no shift, no alt.
    Admittedly, I had to go back and RTFM to be sure.
  • dukepro
    dukepro over 14 years ago in reply to e14 Contributor
    e14 Contributor over 14 years ago in reply to dukepro
    Lorenz
  • rickford66
    rickford66 over 14 years ago in reply to dukepro
    I'll give that a shot.  Thanks.
  • dukepro
    On 05/10/2012 01:44 PM, rickford66 wrote:
    How do I change all fonts to vector on the same PCB at the same time?
    I know it probably has something to do with the group command, but
    not sure of syntax.  Also, how do I select the thickness (%) of the
    font accross the board too? Thanks.
    Two steps:  First smash all the parts to make sure you can access the
    part names, then change the font and ratio.
    To smash all the parts, try:
         display none tOrigin bOrigin;
         group all;
         smash (>0 0);
         display last;
    To change the font and ratio, try:
         display none tNames bNames;
         group all;
         change font vector (>0 0);
         change ratio 15 (>0 0);
         display last;
    Enjoy,
        - Chuck
