EAGLE User Support (English) Explain keepout please
  • Views 2758 views
My manufacturer asks me to put some more spacing around 0402 components
specifically, and I thougt I could do that with the keepout layer, however I
see errors in that layer that makes me wonder what this layer REALLY looks
for.
Manual of 5.12.0 says:
"Keepout:
Restricted areas for components drawn in layer 39, tKeepout, or 40,
bKeepout, lie one upon another. This check is executed only if layers 39 and
40 are displayed and if the keepout areas are already defined in the
Package Editor of the library."
It does not check keepout on keepout, cause that doesnt make sense.
It doesn't seem to check for keepout on pads/smd's, cause the DRC errors I
saw didn't highlight that.
So my question is, what does it really check for?
(the holes in the pad's are microvias)
See attached img:keepout error with blue keepout..
The attached drawing should pass DRC imho.
    Hmm. Cadsoft usually isnt this slow to respond. I guess they DO answer Q's
    for older versions even if bugs are not fixed?
    Quote:
    So in your image there will be a DRC error as your blue keepout
    areas
    overlay each other.
    The small blue wedges are errors because of lack of pad clearance
    and not to
    do with keepout
    Morten replied
    Not true. The highlighted stuff says "keepout" in the DRC list.
    Yes, apologies to all for the incorrect statement.. I did not really feel
    my statement was correct, after I pushed 'send' but it did not look right
    for Keepout notification either so I have now revisited it. Attached is a
    clearer view of what is being displayed and I feel it is a bug and should
    be fixed if it is occurring in v6
    The image on the left is the DRC keepout error highlighting and on the
    right what I would expect. A clearer and more accurate depiction of the
    offending area (Blue area).
    Would Cadsoft please review and comment.
    Warren
    "Warren Brayshaw" <warrenbrayshaw@paradise.net.nz> wrote:
    >> components specifically, and I thougt I could do that with the
    >> keepout layer, however I see errors in that layer that makes me
    >> wonder what this layer REALLY looks for.
    >> "Keepout:
    >> 39 and 40 are displayed and if the keepout areas are already defined
    >> in the Package Editor of the library."
    >> errors I saw didn't highlight that.
    Hi Morten
    The answer is Keepout to Keepout
    Elsewhere in the manual it describes using a rectangle over the complete
    part or a wire frame surrounding your part. DRC  checks that no two keepout
    objects intersect.
    That implies that unless all your packages define keepout areas then the
    presence of one is useless. I would have thought that a keepout on one part
    would flag an error if another part was inside its keepout area, like a
    solitary star ship with its sheilds up. Alas no, I have just tried it and
    other parts can be within the keepout area of another part.
    So in your image there will be a DRC error as your blue keepout areas
    overlay each other.
    The small blue wedges are errors because of lack of pad clearance and not to
    do with keepout
    "Keepout:
    Hi Morten
    objects intersect.
    overlay each other.
    do with keepout
    HTH
    Warren
    news.cadsoft.de
