EAGLE User Support (English) sort() problem on win7?
  • Replies 7 replies
  • Views 599 views
Im trying to run my ULP's on my new win7 computer & Eagle 5.12.0, and I have
this script locking up totally (full core usage, not responding). I have
traced it down to the sort() function, and I wonder if anyone else have
problems with this?
It doesnt even work when run in xp mode...
    http://www.cs.ubc.ca/~harrison/Java/sorting-demo.html
    This provides a visual comparison of sorting algorithm speeds.
    news.cadsoft.de
    Just to inform you why I sort this many entries..
    I have several scripts that work on collecting data. One is my own gerber
    creator wich initially finds all apertures by putting all wire thicknesses,
    smd's and pads onto an array, sorting them by different parameters, and
    finding unique by scanning the table for changes.
    I have a unusually large board, so I get unusually many entries in the
    table.
    As a workaround I've done some initial filtering, like not adding the same
    aperture again wich reduced the array size alot..
    But my initial question is if this is slower on win7 than on xp? I had my
    scripts run many times before and I didnt think I added much data after
    upgrading my pc (although there is a chance I may have overlooked
    something)..
    Thanks for checking it up.
    "Richard Hammerl"  skrev i nyhetsmeldingen: jpigf6$s0t$1@cheetah.cadsoft.de
    On 23.05.2012 13:00, Bernhard Schweighofer wrote:
    On Wed, 23 May 2012 12:06:47 +0200, Richard Hammerl wrote:
    >> On 16.05.2012 12:27, Morten Leikvoll wrote:
    >>> ... 22min...
    >> ...16 mins...
    That's a joke, isn't it? Sorting 310000 entries shall take more than ten
    minutes?
    I've just generated a "dummy" text document (39 MBytes in size, 3851264
    lines - so the entry number is more than ten times as high as in the
    example) - sorting (not with eagle, but with the operating system sort)
    takes less than 2 seconds with a "core i5-2500" CPU...
    What kind of sort algorithm is eagle using - bubble sort?
    regards
    Bernhard
    Don't know which algorithm is used for that because I am not a
    programmer, but maybe sorting 310000 objects is not the main task
    of ULPs....
    Nonetheless I will forward this to our development guys.
    >>> ... 22min...
    >> ...16 mins...
    minutes?
    regards
    Bernhard
    of ULPs....
    Richard Hammerl
    >> ... 22min...
    ...16 mins...
    minutes?
    regards
    Bernhard
    I tested the same code on an old pentium 4 2.8GHz running xp 32bit and
    it executes in 22min.
    I expect ALOT better performance on the new i7.
    My laptop with Win7 32 bit and a i5 M520 @2.40Ghz needs 16 mins for it.
    Richard Hammerl
    I tested the same code on an old pentium 4 2.8GHz  running xp 32bit and it
    executes in 22min.
    This appears to be some very slow phenomena.. Sorting 310k integers (2 deep)
    takes up to 10 minutes on a brand new i7-3820 (3.6GHz, 16G mem, 64bit win)
    Is this normal? Does eagle make temp files on system drive? (got flashdrive
    now if that matters). Im pretty sure this was a lot faster on my old
    computer.
    It looks to me like this is a bubblesort algorithm cause an already sorted
    dataset is very quick.
    Can anyone try this ulp and check the creation time of the start and stop
    files created? This specific example takes 10min on my computer.
    ulp starts here----
    output ("Start.txt")
        printf("Start time is file creation time");
    int i=0;int a[];int b[];int index[];
    for(i=0;i<310000;i+) a[i]=-i;b[i]=-i;i+;
    sort(i,index,a,b);
    output ("Stop.txt")
        printf("Stop time is file creation time");
