EAGLE User Support (English) How can I restore the scheme?
  • Subscribers 191 subscribers
  • Views 2601 views
daomsk
daomsk over 14 years ago
Yesterday I  drawn a scheme, has placed the the elements on the board, and
saved the project. Today I  open the project, but instead to open the
scheme, a message appears:
"Error:
line 14620, column 6: redefinition of name 'GND' in tag " image
Figure PCB displayed normal, as I saved yesterday. All connection on the
circuit board shown is correct.
How to restore the scheme? How can I restore the circuit device, if there
is a proper circuit board? I drawing scheme at once, without intermediate
saves, so files *. S # * - do not have.
I'm using EAGLE version 6.1.0.
All's well, that ends well
  • p1234321
    p1234321 over 7 years ago
    I have the same problem. I tried using the backup file, but the problem is still there.
    i cannot open my file anymore!
    please help!!!
    thank you very much
    paul
  • willfras
    willfras over 8 years ago in reply to e14 Contributor
    THANK YOU!!!
    Saved me from a heart attack after I hit "do not save" after hours of work!!
  • daomsk
    daomsk over 14 years ago in reply to e14 Contributor
    Brett, thank you for your answer, but first, I wrote that the painting scheme quickly and at one time, so the intermediate values *. S * are not available. Secondly, I got help from Richard_H.
    I sent him a scheme, and he restored it. It was an internal error in the XML format into the EAGLE.
    Sincerely yours, Alex
    If you have auto-save (Options|Backup in control panel) set to "On" then
    Eagle will automatically create project.s## (and also project.b## if you
    have a PCB in work) at the selected interval. Go to the project folder and
    rename project.s## to project.sch and you will be back in business.
    "Alex" <daomsk@gmail.com> wrote in message
    news:jor9k1$33n$1@cheetah.cadsoft.de...
    "Error:
    line 14620, column 6: redefinition of name 'GND' in tag <bus>" image
