EAGLE User Support (English) Assembly Variant Question
  • Views 325 views
Hi
Using Eagle 6.2.0 with XP PRO SP3.
Assembly Variant:
When a Component is not selected in the table from Assembly Variant
Dialog, the Printed Circuit Board still displays the component
but only shows the Airwires and Pads, is this a normal behaviour
of this feature ?
If yes how do I get rid of the component from the PCB?
PM
    Jorge
    Thanks for answer, now I understand the concept.
    I was trying to make 2 diferent PCB's Layouts and not
    just have a board with un-populated parts.
    PM
    On 18/05/2012 4:07 AM, Jorge Garcia wrote:
    On 5/16/2012 7:03 PM, Peter Maroudas wrote:
    >> Hi
    >> Assembly Variant:
    >> of this feature ?
    >> PM
    Hi Peter,
    The component pads always stay behind, even when a component is selected
    to not be populated. The silkscreen and reference designators are
    removed but the pads are always left behind.
    The only way to really get rid of the pads is to delete the component.
    The idea behind the variants is to indicate an unpopulated component, or
    different component values or something to that effect.
    Best Regards,
    Jorge Garcia
    Hi
    Assembly Variant:
    of this feature ?
    PM
    Hi Peter,
    Best Regards,
    Jorge Garcia
