I've got a problem when I view my board in GC prevue - usually use this as a
final check.
Just did a simple single sided board with two holes on it (no vias).
Outputted the job as I normally do then import the 274x gerbers and excellon
drill file into GC Prevue. Everything looks OK except my two drill holes
that are way outside the board area.
Everything looked good in Eagle 5.11.
When running the CAM job, I no warnings.
Don't know if it is significant, but this board was imported as a DXF using
DXF to Eagle Script converter (part of Eagle power tools 5). Initially I had
no drills at all in the output and realized that a Circle in the Holes layer
does not create a drill. I exchanged this for a Hole and I got my correct
hole legend on the eagle drawing.
In GC Prevue, I import just the drd (drill data file) and got the two holes
(diameter was right but locations were way off).
Any ideas what might be causing this?
Bob Oppenheimer
