It would be very helpful if the net label size could be set separate
from the text size.
It is rather annoying to write a rather big text and after that placing
some labels pop up in that unwanted size.
Very often it is also necessary to change the net label xref=off to
xref=on.
The size is then equal to the label size plus the frame, which again
means it might not fit anymore.
Perhaps it is possible to calculate the outer size equal to xref=off size.
Joern Paschedag
