EAGLE User Support (English) Clearance from Ground Plane on certain nets?
  • Subscribers 187 subscribers
  • Views 271 views
  • ground_plane
  • clearance
  • nets
Is there a way to specify that you want more clearance between the ground plane and certain nets (wires) etc?  If I set the clearance in the Defaults I get good clearance on most nets but there are a few higher current nets I would like to increase the clearance on.
    Exactly what I was looking for thank you.
    Have a look at "Net Classes".  You can define the width and clearance for
    nets in each class.
    HTH
    Warren
    news.cadsoft.de
