EAGLE User Support (English) error:  some objects extend outside the allowed board area
  • Subscribers 189 subscribers
  • Views 984 views
ulao
ulao over 14 years ago
I have loaded an old board I wish not to redo and everytime I try to moving somthing I get this error:
The light edition of Eagle can't preform the requested action!
some objects extend outside the allowed board area.
The board does have a number of lines ( not just 4 ) but they over lap so it looks closed, not sure if this is my issue. Even if I move an object clearly in the board area it says this. What could I have done? Is there a way to have EAGLE re draw my board?
  • ulao
    ulao over 14 years ago in reply to e14 Contributor
    I dont recal the version I used but now I have
    Version 6.1.0 for Windows Light Edition
    I tried to look at a brd file from a back up of my project and it does not include the version where is 6.1 brd files do? So I dont know how I can get the version. It was created in 07-08 if that helps.
    e14 Contributor over 14 years ago in reply to ulao
    ulao ulao wrote:
    Posibly I used the limited lic. when i created it? I just never had
    that issue before. I know I never used a purchaced lic for it? If
    there is a free limited lic. where might one obtain this?
    Which version was the old board created with?
    Which version are you trying to open it with now?
    Warren
    news.cadsoft.de
  • ulao
    Posibly I used the limited lic. when i created it? I just never had that issue before. I know I never used a purchaced lic for it? If there is a free limited lic. where might one obtain this?
    That message is presented when you try to place an element outside of the
    permitted limits for your version of the software.
    The points that are tested are the element's origin and the pad centres of
    that element(package).
    The limited versions of the software will let you load designs that are
    beyond the limits but not let you relocate a moved element (package) outside
    the limit area.
    You can place all other objects beyond the limits (if I remember correctly)
    HTH
    Warren
    news.cadsoft.de
