EAGLE User Support (English) Change the beaviour of the selection Tool in Schematic
  • Views 224 views
nickstomp
nickstomp over 14 years ago
The select method and then for example (move group) are very strange
The user wants to select objects clicking in an empty area of the schematic and dragging a square around objects and the if move command is selected
expect that the default behaviour is to Move group not the nearest object!!!!
    "Nicola Lunghi" <noreply-103911@element14.com> a écrit dans le message de news:
    948207117.19941339392278989.JavaMail.jive@flmspu-csapp-02.premierfarnell.com...
    The "normal" method for Moving a group is as follow:
    1) Select the MOVE button
    2) Select the GROUP button
    3) Press the left button (of the mouse) and drag a rectangle around some objects
    4) Release the left button: the group is selected and the MOVE button remain active
    5) Click the right button and choose "Move: Group" in the context menu
    6) Move the group and click left: as you can see the move command is still active, either for
    moving a single element or a new group
    You can also do the group first and select the move button after, but that's "one shot" because the
    move command does not remain active.
