EAGLE User Support (English) Where is the syntax manual for ULP?
  • Subscribers 189 subscribers
  • Views 728 views
phoenix710
phoenix710 over 14 years ago
All:
I've been programming in C since '83, and ULP programs (as noted in the
manual) are indeed very similar to C. My first need is to write a ULP
similar to normalize-text.ulp, but with some additional features. I've
spent some time looking in this forum (and google generally) for
information leading to a manual on the objects available for use within a
ULP, but haven't found the link yet.
For example, in the normalize-text.ulp code I see an object "UL_BOARD" that
has a property "layers" (accessible with the dot operator); moreover the
"layers" property has a dot-accessible property "visible". There is another
object "UL_TEXT" with dot accessible object "layer", and so on.
My question is, where do I find a list of the objects that are available to
the ULP, a hierarchy of the objects, and the general syntax of the ULP code
file itself. The rest of the ULP is so similar to C that I'm sure I could
find my way around, but I need the objects and their hierarchy.
Thanks.
Dave
Designing and building audio HW for the DIYer.
  • dukepro
    dukepro over 14 years ago
    Good morning, David,
    Ha!  Got ya beat.  I started C in 1979, shortly after K&R published the
    first edition of the bible.  I guess that dates us somewhat eh?
    file itself.
    Try: ftp://ftp.cadsoft.de/eagle/userfiles/doc/ulp5120_en.pdf
    The also have a german version of the same manual, if you prefer.  I
    don't see a download for 6.x ulp.
    HTH,
        - Chuck
    perhapse under: "User Language - Object Types" in the online help?
    Lorenz
