EAGLE User Support (English) re: Bug? Library parts silently auto connecting (dated 6-20)
  • Replies 9 replies
  • Subscribers 189 subscribers
  • Views 812 views
I have a bunch of libraries with Pwr pins that need re-directing.
I've found it time consuming and error prone to go through each library and
attempt to change offending pins' direction from Pwr, to Pas for instance.
Does anybody have a script or ULP handy to search the various libraries and
change any pins with direction Pwr, to some other direction? (Of course,
SUPPLY libraries must be hidden by user, or somehow skipped!)
Or, could somebody write one? I know that is a lot to ask but I am useless
when it comes to writing scripts and ULPs.
Please, somebody?
    e14 Contributor over 14 years ago in reply to dukepro
    That sounds simple, thank you. I guess now I have one less reason not to
    upgrade (again). Eagle gave me extreme heartburn with the bugs in early v6.
    I reverted back and have been in no hurry to jump again despite promised
    imprevements.
    "Chuck Huber" <chuck.huber@dukepro.com> wrote in message
    news:jseua6$h3s$1@cheetah.cadsoft.de...
    Aren't the libraries maintained in XML now?
    So why not just use a plain text editor like vim or notepad and do a
    global search and replace in the library file?
    Try replacing
       direction="sup"
    with
       direction="pas"
    Make a backup first, of course.
    Enjoy,
       - Chuck
    On 06/26/2012 10:57 PM, Brett Holden wrote:
    >> I appologize for going off. If my request is too difficult without
    >> resorting
    >> to Linux or an Linux emulator (or whatever), then that's just tough
    >> nuggies
    >> for me. Maybe also for however untold numbers of persons who
    >> inadvertently
    >> created libraries using Pwr pins that will get connected automatically,
    >> to
    >> untold dismay. But I'll just speak for myself. The most expeditious way
    >> to
    >> correct the conundrum may be going through each library one-by one. No
    >> big
    >> deal, I'm used to bigger trouble than that.
    >> A note to CadSoft. So, that's the way you've done it for 20 years?
    >> I suppose if It was good enough for my daddy then it should be good
    >> enough
    >> for me, eh?
    >> You can call anything you want a non issue and simply ignore it.  Sure,
    >> Eagle is "EASY" as in "Easily Applicable". Really? Maybe if you're a
    >> programmer.
    >> "Robert Pearce" <news@bdt-home.demon.co.uk> wrote in message
    >> news:bWYIrHNOo45PFwMN@daniel.huneausware.local...
    >>> On Sat, 23 Jun 2012, Olin Lathrop wrote to us saying :
    >>>> Robert Pearce wrote on Fri, 22 June 2012 18:57
    >>>>> What do you mean, you don't know what SED is? Honestly, what sort of
    >>>>> garbage OS are you using? Oh, I see, Windoze. Well.... there is the
    >>>>> GnuWin package to repair that problem.
    >>>> The garbage I see here is expecting a user of one operating system to
    >>>> know
    >>>> commands of another, a religious diatribe masquerading as a helpful
    >>>> answer,
    >>>> and your proposed method of changing power pins.
    >>> Nothing religious about it. Windows lacks any useful tools, but I
    >>> offered
    >>> a solution to that.
    >>>> Your method basically creates a whole new library, which then no longer
    >>>> has
    >>>> association to the various projects that uses it.
    >>> Unless it has the same name, in which case Eagle's method of associating
    >>> libraries can easily be made to find it.
    >>>> A better way would be to
    >>>> write a ULP to scan a library for power pins, write the Eagle commands
    >>>> to
    >>>> change them to whatever you like, then run those commands on exit from
    >>>> the
    >>>> ULP.
    >>> Which I note you have not done, because it's not nearly as easy as my
    >>> approach.
    >>>>  This has the advantage of editing the library in place.
    >>> That's not an advantage because you don't really want to go hacking all
    >>> your libraries "in place" and then find you've messed up. FAR better to
    >>> create new ones, check they work, and then either copy them over the
    >>> originals or BETTER STILL use the custom ones from now on leaving the
    >>> originals still available should you ever choose to go back.
    >>> You and Brett may choose to see my genuinely offered help as a personal
    >>> attack or a religious diatribe. If so, you are the only ones who lose
    >>> out.
    >>> Rob Pearce                       http://www.bdt-home.demon.co.uk
    >>> The contents of     | All power corrupts, but we need electricity.
    >>> this message are    |
    >>> purely my opinion.  |
    >>> Don't believe a     |
    >>> word.               |
    >> Try replacing
    >>      direction="sup"
    >> with
    >>      direction="pas"
    Or replace
         direction="pwr"
    with
         direction="pas"
         - Chuck
    Hi Chuck,
    You're the man, I like how you can quietly swoop in, provide an easy
    solution without getting involved in the Linux vs Windows war.
    Good job.
    Best Regards,
    Jorge Garcia
    Cadsoft Support
    Am 27.06.2012 14:31, schrieb Chuck Huber:
    >> Try replacing
    >>      direction="sup"
    >> with
    >>      direction="pas"
    Or replace
         direction="pwr"
    with
         direction="pas"
         - Chuck
    That is too easy chuck image
    Joern Paschedag
  • dukepro
    dukepro over 14 years ago in reply to dukepro
    Try replacing
        direction="sup"
    with
        direction="pas"
    Or replace
        direction="pwr"
    with
        direction="pas"
        - Chuck
  • dukepro
    dukepro over 14 years ago in reply to e14 Contributor
    Try replacing
        direction="sup"
    with
        direction="pas"
    Enjoy,
        - Chuck
    I appologize for going off. If my request is too difficult without resorting
    to Linux or an Linux emulator (or whatever), then that's just tough nuggies
    for me. Maybe also for however untold numbers of persons who inadvertently
    created libraries using Pwr pins that will get connected automatically, to
    untold dismay. But I'll just speak for myself. The most expeditious way to
    correct the conundrum may be going through each library one-by one. No big
    I suppose if It was good enough for my daddy then it should be good enough
    for me, eh?
    programmer.
    >>> The garbage I see here is expecting a user of one operating system to know
    >>> answer,
    >> Nothing religious about it. Windows lacks any useful tools, but I offered
    >> a solution to that.
    >>> has
    >>> write a ULP to scan a library for power pins, write the Eagle commands to
    >>> change them to whatever you like, then run those commands on exit from the
    >>> ULP.
    >> approach.
    >> attack or a religious diatribe. If so, you are the only ones who lose out.
    >> this message are    |
    >> Don't believe a     |
    >> word.               |
    for me, eh?
    programmer.
    >>answer,
    a solution to that.
    >>has
    >>ULP.
    approach.
    this message are    |
    Don't believe a     |
    word.               |
    >commands of another, a religious diatribe masquerading as a helpful answer,
    offered a solution to that.
    >Your method basically creates a whole new library, which then no longer has
    >ULP.
    approach.
    out.
    this message are    |
    Don't believe a     |
    word.               |
    association to the various projects that uses it.  A better way would be to
    ULP.  This has the advantage of editing the library in place.
    On Thu, 21 Jun 2012, Brett Holden wrote to us saying :
    Assuming you want to change ALL the power pins in a given library (so
    you won't do this with the supply.lbr for example) then:
    1) Export the library as a script (from the library editor File menu)
    2) Run "sed -i s/Pwr/Pas/g" or similar on that script
    3) Create a new library and import that modified script
    4) Save the resulting library in your "custom" directory
    You may need to tweak that sed command a fraction, but that's the
    essence of it.
    this message are    |
    Don't believe a     |
    word.               |
