EAGLE User Support (English) best text size?
  • Replies 10 replies
  • Subscribers 190 subscribers
  • Views 2098 views
best text size?
fritzz
fritzz over 14 years ago
I am making components for libraires, but I don't want all different font sizes as I use my custom ones and the standard ones.
What is the most common size so I can try to match as I make mine?
  • fritzz
    fritzz over 14 years ago in reply to e14 Contributor
    Thanks very much.
    I'm going to use 50mil and 10% and propose that becomes the standard. image
    Your objectives are to make silkscreen text printable and readable.
    Check with your board house what minimum silkscreen width they can
    reliably print.  Olimex, for example, specify 10mil (0.254mm), other
    board houses give a figure of 8mil or sometimes 5mil.
    You will then need to choose a text size that is comfortable to read
    when assembling/debugging boards.  I go for 50mil (1.27mm) but this is
    quite large.  The best way to find out what works is to print a
    life-sized copy of the silkscreen layer.
    To meet the silkscreen width requirement of your board house you will
    need a suitable "Ratio" setting.  I use 20% which, for 50mil text, gives
    10mil thickness.
    You will see that most of the EAGLE standard libraries use 50mil text
    and either 8% or 10% ratio, giving rather feeble 4mil and 5mil
    silkscreen widths respectively.  Some board houses will struggle to
    print these.  When I use standard parts, I usually "SMASH" them and
    change the ratio of "tNames"-layer text to 20%*.
    For non-silkscreen drawings or text (e.g. "tValues" and "tDocu" which
    are generally not printed on the PCB), which are used to produce
    assembly/test documentation, you have much more freedom.
    In schematic symbols, 0.07 inch text (with 8% ratio) is standard.
    In a thread on "eagle.userchat.eng" in November last year, Jeorge Garcia
    of Cadsoft proposed a set of standards for libraries.  I'd be interested
    to see if this took off.
    Andrew
    0xADF
    • display none tOrigins bOrigins; group all; smash (>0 0); display last;
    display none tNames bNames; group all; change size 50mil (>0 0); change
    ratio 20; display last
  • fritzz
    It's not an issue for routing to have most parts packages sized for .100 grid, and then plaved in a metric grid?
    e14 Contributor over 14 years ago in reply to fritzz
    d b wrote on Mon, 02 July 2012 02:45
    I have all editors set to inches.
    Do you mean .07 inches for schematic but metric .8 mm for
    footprints?
    Rigth now I'm set to .05 inches and 10% for foorptints. Possibly way
    too big from what you are saying.
    A standard CAD Schematic (at least here in North America) is always in
    0.1"-grid, not just in EAGLE.  So I stick with that.
    But PCB can be anything you like and I prefer metric.  But obviously you
    could convert that to inches if you'd like.
    I was giving the smallest, you can make it bigger at will.  When silk gets
    too small then parts of the text will either blob or thinned out too much.
    But big isn't a problem.  I find 1mm to be a good size but others may have
    different opinions.
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
  • fritzz
    Do you mean .07 *inches* for schematic but metric .8 *mm* for footprints?
    Rigth now I'm set to .05 inches and 10% for foorptints. Possibly way too big from what you are saying.
    d b wrote on Fri, 22 June 2012 21:25
    For schematics and symbols, 0.07" is best since it can be centered in the
    standard 0.1" grid.
    For pcb and footprints, I find that 0.8mm in the vector font and ration of
    15% is the smallest that I can get to be reproducible across a bunch of
    different manufacturers.  If you're using a more advanced PCB process you
    can usually get to 0.6mm.  Always use the vector font in the PCB.  If you
    use Proportional font then the size can change between the screen and the
    gerbers.
    Now my designs are usually dense so I try to get the smallest.  For sparser
    designs I use 1mm size and that seems pretty good.  It really depends on
    your design and how small you can read image
    Cheers,
    James.
  • Kalimuthu
    Kalimuthu over 14 years ago in reply to fritzz
    12 pt. Ref - MS OFFICE
  • fritzz
    fritzz over 14 years ago in reply to Kalimuthu
    12? Do you mean a ratio of 12?  What size?
  • fritzz
    Also, is there any way to go thru a whole library and change text size, or do I need to look them one by one?
  • Kalimuthu
    Font size 12 is best. 10 may use for compact.
